Aluminum welders inside
Please let me know,
Dan
Please let me know,
Dan
1...with spool gun wire size can be .063, probably for LARGE pieces requiring lots of amps. for smaller pieces try .035 aluminium 5053, good all around wire for your application.
2...the pieces must be clean immediately prior to welding...either sand blast, then wire brush or plain wire brush.. this remove the oxides that build up on the surface.
3... use pure argon as your shieding gas @ about 35- 45 cfm
4... wire speed must be adjust acordingly to amperage. EX;more amps , more wire is needed to fill.
5.. direction of travel.. best to travel away from deposited metal..lettiing the gas flow over the newly form weldment
6...speed of travel IS important. moving to fast will leave a thin irregular weld bead..move just fast enough to fuse to edges
7.. for larger pieces that need to joined preheat to about 135f..clean weld immediately
hope this helps.. if you need more info i be glad to help
although I would add that a TIG welder is easier than those darn spool guns for welding aluminium. If you don't have much to weld I'd take it to someone with a TIG (heliarc).
Good advice. I'm good with my mig on steel but I suck when it comes to aluminum. I think it's more the process than me
Practice, practice, practice
I'm lookin for a tig and a plasma cutter. There's 2 more for the list Santa, i hope your reading this
if you interested, i have complete tig welding outfit( i think 20 foot lead, 150amps, small handle )..seening that it is xmas i'll through in some tungten 2% (red tip) . It is on my welding truck.rig, complete with argon flow guage..
as for the aluminium and mig.. you can change the liner in your lead cable to poly and push aluminium through the whip ( no more then 6 ft) with good results..(kits available @ local welding supply dealer or Princess auto).. or a spool gun @ an additional 500 -600 bucks extra. if you have miller welder, that takes one.. rewiring any mig welder to accept is not difficult.
as for the plasma cutter...Mine is made by thermal dynamic and will cutting 3/4" plate very easily. All that for the price of a mere 3800.00 bucks, but there must be some used equipment out there that cuts up 3/8" for a lot less...
check out these pics: lots of tig welding here..stainless steel Mini chopper framehttp://members.shaw.ca/vettek/Picture%20164.jpg
http://members.shaw.ca/vettek/Picture%20177.jpg
ps: santa direct line was busy when i tried to contact him for my wishes
http://www.suppliersonline.com/Resea...erty/step1.asp
http://www.onlinemetals.com/
