96 LT1 Timing question?
Old Dec 26, 2004 | 04:24 AM
Sinister87's Avatar
Sinister87
Default 96 LT1 Timing question?
I believe my optispark gave up the ghost, so I'm going to replace it. Eventually, I would like to do a cam swap. I have seen in the past on this forum, that you guys have mentioned a book that is like the bible for doing cam swaps on these optispark engines. I guess it goes in detail about setting the timing with the optispark and what's involved. So if any of you know what book I am talking about i'd appreciate the title and where I can purchase the book in question, thanks in advance.
Old Dec 26, 2004 | 05:13 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I have the book on how to rebuild an lt1 if that might help?
Old Dec 26, 2004 | 07:09 AM
Sinister87's Avatar
Sinister87
Keep it handy, you might need it someday
Old Dec 26, 2004 | 09:07 AM
STL94LT1's Avatar
STL94LT1
Default Camshaft Install
There is no setting the timing with the opti spark, it only goes in one way. The timing is set thru the PCM on the LT1/4's.
Here's a great write-up by forum member Jim "96GS#007" Mason, on swapping camshafts in the LT1/4.
http://www.hashmarks.com/techtips/hot_cam.htm
Old Dec 26, 2004 | 11:37 AM
Sinister87's Avatar
Sinister87
Thanks STL, i thought you had to line up some slots on the optispark for timing when you install it. I haven't really read up on it yet but I remember forum members here refering to a book about it. As far as the cam install, I have that covered as I've done a couple of those, I'm just not familar with the optispark, thanks for your reply.
To 96 LT1 Timing question?
