Help Removing TPI Intake Runners
Old Dec 26, 2004 | 02:40 PM
B387's Avatar
B387
Default Help Removing TPI Intake Runners
I need help from somebody who has done this. I have all of the bolts out, but the runners don't seem to want to disengage from the manifold. They are loose, but still seem stuck. I don't want to pry them with anything for fear of breaking something. Any tips? Thanks for the help.
B387
Black 87 Vert 128,000mi
New custom Interior
Working on the engine now.
Old Dec 26, 2004 | 02:51 PM
JackDidley's Avatar
JackDidley
Alot of guys miss the trick bolts. Look close. You have a bolt on each side that is removed from the opposite side. They go through the base and into the runners. Check close before prying.
Old Dec 26, 2004 | 02:58 PM
Wayne88's Avatar
Wayne88
There are a few inside bolts you may have missed, look closely along the inside of the runners.
Old Dec 26, 2004 | 03:24 PM
B387's Avatar
B387
I got both bolts from the inside. They're two one on each runner, but it still seems stuck???
Old Dec 26, 2004 | 03:30 PM
Wayne88's Avatar
Wayne88
If there is nothing else holding it, I would use a little strength.
Try lightly prying it, it has to come off, the gaskets are keeping it on.
Probably has that gasket glue on each side of the gaskets.
Old Dec 26, 2004 | 07:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
Make sure all the lowers are out. They can be hard to see. Try pulling out first instead of up. You may be hitting the fuel rails
Old Dec 26, 2004 | 08:23 PM
1fast91's Avatar
1fast91
just removed mine, there are two bolts hard to see. they are on the inside under the plenum.
Old Dec 26, 2004 | 10:20 PM
B387's Avatar
B387
Well, this is how it goes. First it was the two bolts between the runners down by the rocker cover that I was missing. Feel totally stupid. Then, as if I wasn't having enough fun, the bolt on the A/C under the clutch is a Torx 40 which stripped when I tried tried to take it out. Seems like a strange choice of heads for a bolt that gets pretty frozen in after 17 years. I guess the A/C will stay on until I get the engine out. This is my first computer FI, and I can't tell if I'm having fun yet.
Thanks to all those who helped. I'm sure you'll hear more about this adventure in the upcoming weeks.
B387
Old Dec 27, 2004 | 11:10 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Everybody here who does their own wrenching has been where your at. Just holler and we'll try to help.
Old Dec 27, 2004 | 01:46 PM
B387's Avatar
B387
I love this place. Thanks again
B387
Old Dec 27, 2004 | 05:58 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The bolt under the a/c can also be removed with a 12mm or 1/2" open end wrench, i forget which.
There are 20 bolts in total holding the runners on. 8 on the upper flanges, 12 on the lower.
To Help Removing TPI Intake Runners
