Finally have some dyno #'s
Gary
Gary
One thing is for certain - a car might put up good dyno numbers, a car will NOT put up track numbers with out the power. As some said, be happy you have a good TRACK number. Anyone that wants to argue with you they have more power, dyno or whatever - take them to the track and open up a can of whoop azz on them.
....i have 640+rwhp and with a best et of 10.66 (don't know your #'s) and 1.622 60'. i know my et should drop big time as soon as i switch to auto trans....
These guys get increadibly HUGE azz numbers. In the 500+ rwhp range for most. This dyno has to be the most greased up unit ever! Anyways I usually get about 3 phone calls to bring out my car - but never do, as I see its a total waste of 50 dollars per run. And they always talk you into 2-3 more. So by the time you leave your 200 beans poorer.
The next day while these guys are still all "puffy-chested" we run at the airport track through the 1/4 mile. I beat every one of them by at least 2-3 cars, pulling on them BIGTIME at the topend. Some I beat by a rediculous amount - like a 1/4 of the track.
These guys in comparison to my car and their obtained dyno #s think I am making over 800rwhp.
My setup is LUCKY to be making a TRUE 600+ fwhp. Its probably more in the 570fwhp range. Believe me its VERY hard to make N/A power. That would be about 450rwhp, so use that as a reference to some of the numbers you see posted on this board and with these number not even in the 11s when they hit the track.
That means they are 2 sec slower, with nearly the same HP. At the end of the day, I am being honest with my HP numbers, and obviously my ETs. And I am sure these dyno print outs are true, in that they obtained them. But reality says something is WAY WAY off, hence my reasoning for saying dyno #s are
I will have to check after it leaves next time where it was sitting, there is probably an oil slick - similiar to the Exonvaldese
