Vibration problems
Old Dec 27, 2004 | 06:47 PM
sugarwolf's Avatar
sugarwolf
Default Vibration problems
Well i have been having vibration problems going over 70mph in my 96 vete lt4. I feel it in the steering wheel and in the seat. Its not to bad but does get annoying i had tires re balanced and didint help. I know my breaks are getting bad becasue when i try to slow down from going 70+ they really vibrate then. Wonder if the rotors are doing it? Any ideas?
Old Dec 27, 2004 | 07:14 PM
sugarwolf's Avatar
sugarwolf
Got to be somone out there that has had that problem before?
Old Dec 27, 2004 | 07:27 PM
projectnightmare's Avatar
projectnightmare
Two things - brakes could be a part of the vibration but also the lower ball joints could be wearing out - Hard driving or high milage will over time wear out the ball joints. If you don't know how to check for wear in the ball joints, I would suggest going to a local vette service shop to have them checked. It also could be someting as simple as a tire going bad - a sidewall cord could have snaped or you might have a small bubble. Check these first to conclude... It's most likely something simple.
Old Dec 27, 2004 | 09:50 PM
BLK/BLK'93's Avatar
BLK/BLK'93
Does it do it with the top on? Most C4's will have vibration with the tops removed. With the top removed, the car flexes more creating the type of vibrations you are referring to. I have driven over 8 C4's, and they all have this issue.
Old Dec 28, 2004 | 12:38 AM
sugarwolf's Avatar
sugarwolf
Its with the hard top on it does it. Car has only 50,000 miles on it and has done it since i got it.
Old Dec 28, 2004 | 07:58 AM
runner140*'s Avatar
runner140*
Default I think you might have a......
Warped front rotor. Or it could be a series of small items,(parts) that are either worn or broken. When you are a speed and you apply the brakes, does the viabration get worse. That would be the test for a warp of the rotors. Just a guess.
Old Dec 28, 2004 | 12:41 PM
John Robinson's Avatar
John Robinson
Default Something else to check
On my 93 coupe I found a bent right front rim on the inside from the previo se owner
Old Dec 28, 2004 | 04:23 PM
Perfusion's Avatar
Perfusion
The worsening of the vibration upon braking is a dead-wringer for a rotor, but the vibration at speed is another story that doesn't *necessarily* have to be the rotor. It could be bearings, U-joints, ball joints, tie rod ends, tires, bent rim, etc., etc., etc. Vibrations are really a royal b!tch to diagnose, IMO.
FWIW, my 96 LT4 w/ 50k miles has a vibration at exactly 63mph (in any gear) that nobody has been able to figure out. The incorrect way to fix it would be to just start throwing money at the car by replacing part after part until it's gone, but I'm not in a position to do that. Hopefully, I'll one day find it. Sometime early next year, I'm going to do bearings/U's just to be on the safe side as "preventative maintenance". We'll see if that does it. I've already replaced a bent rim, and that didn't do it, nor did 4 new tires...
To Vibration problems
