700 R-4 Transmission
Old Dec 27, 2004 | 09:30 PM
gmusil's Avatar
gmusil
4th Gear
Default 700 R-4 Transmission
I have a rebuilt 1986 truck 700 R-4 that I want to install in my 1984 Corvette. Are there any changes to the lock up solenoid or 4th gear switch that I need to make so that it shifts properly??
I'd appreciate any info . Thanks
Old Dec 27, 2004 | 10:02 PM
#70SM2's Avatar
#70SM2
You will probably need a governor recalibration kit from Summit, $29.00.
your tranny will probably be shifting early, some of that is determined by the gear ratio.
Old Dec 27, 2004 | 11:31 PM
tonymax2's Avatar
tonymax2
Unless that truck uses the same "C" beam driveline connection as a C4, I don't see how you're gonna bolt it in the 'vette. I was under the impression that the C4 trans case was unique to the 'vette. Better check before you take anything apart!
Old Dec 28, 2004 | 10:43 AM
gmusil's Avatar
gmusil
4th Gear
Yes, You are correct. I,m using the C-4 tailshft housing. Thanks for your comment.
Old Jan 2, 2005 | 03:34 AM
PBA's Avatar
PBA
The Vette 700R4 output shaft is .950" shorter than the regular 700R4, and requires the Vette tail section.
Old Jan 2, 2005 | 09:33 AM
rick lambert's Avatar
rick lambert
Check out this web site-www.transmissioncenter.net/700r4.htm
should answer all your questions. Good Luck
Old Jan 2, 2005 | 01:43 PM
TwoFast4Lv's Avatar
TwoFast4Lv
BTW the Corvette case is reenforced more to hold that tail housing in place
Old Jan 2, 2005 | 02:22 PM
CFI-EFI's Avatar
CFI-EFI
Also check the speedo gears and swap them if necessary. Many '84's had a 27 spline input shaft. Everything after '84 used 30 spline. You will want to be sure you are prepared with a converter that fits.
RACE ON!!!
Old Jan 2, 2005 | 03:11 PM
crkemppainen's Avatar
crkemppainen
then you're good to go, as long as the wiring harness connects up the same, then it'll bolt right in
To 700 R-4 Transmission
