MAF sensor screen
Old Dec 28, 2004 | 07:09 AM
vstol's Avatar
vstol
Default MAF sensor screen
I am having PCM for less program a computer for my LT4 Hotcam and he asked if I have the screen removed on my MAF sensor. I have done a little reseach to include TPIS where they show you how much extra flow you get when removing the screen. I have searched the forum and read to threads, I would like to heart some other thoughts, I am sending the work order in tomorrow. Thanks
Old Dec 28, 2004 | 07:14 AM
ClarenceT's Avatar
ClarenceT
http://www.gmtips.com/3rd-degree/dox...maf-screen.htm
Old Dec 28, 2004 | 09:21 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I have a stock LT4. The only mods I have done is the cut lid, ported the MAF, TB bypass, and AeroChamber mufflers. I did not have a dyno done for before and after, but I can say that all of those made a good improvement, or at least enough to feel. The simple freebies that I did can be debated as to whether they have any real improvements or not... but they are free so why not?
I did all of the above all at once so I'm not certain which made a difference and which did not. I can say that before the mods I could not brake the tires loose on a rolling punch... now I have troubles keeping them planted. I hope this helps some.
What year do you have? or motor?
Old Dec 28, 2004 | 10:44 AM
vstol's Avatar
vstol
Thanks, I have the 96 LT4 Hot cam in my 64 Corvette Grand Sport. Clarence, interesting article, if I have the computer (OBD1) programmed to recognize the increase flow would I not see an increase in performance?
Old Dec 28, 2004 | 11:59 AM
kwik_ta's Avatar
kwik_ta
That sounds like a fun auto mobile
Old Dec 28, 2004 | 12:42 PM
GeosFun's Avatar
GeosFun
Volume of air in and air out is what makes power. removing the screens is a simple task, just follow the instructions. Might as well take out the heat sinks while you are at it. The biggest problem with our computer engines is that they are so refined, it is hard to find big power increases in any one place. But lots of little ones add up. 100, 1% improvementrs = 100% improvement.
Old Dec 28, 2004 | 01:26 PM
vstol's Avatar
vstol
The heat sinks are the posts sticking up with in the sensor?
Old Dec 28, 2004 | 02:09 PM
kwik_ta's Avatar
kwik_ta
yes. if you hollow everything except the sensor itself... you should end up with a hollow metal tube with some wires in the middle (the sensor itself). I did mine with a cutting wheel and a dremel. My neighbor used a plasma cutter somehow... the key is to cut the fins out and sand\polish the surface flat. you want a constant flow of air with little to no turbulance.
Old Dec 28, 2004 | 03:33 PM
GeosFun's Avatar
GeosFun
I used a hacksaw to cut the heat sinks out of mine. Put the housing in a vise and some duct tape on either side of the heat sinks on the inside walls to protect the walls.
Old Dec 28, 2004 | 06:33 PM
vstol's Avatar
vstol
Certainly not rocket science thanks
Old Dec 30, 2004 | 03:08 PM
vstol's Avatar
vstol
ok the MAF sensor on the LT4 is a little different, only thing to do is remove the screen. LT4 owners I have 2 sensors on top and three on the bottom, can someone who has a LT4 verify that. I want to make sure I did not break any.
Old Dec 30, 2004 | 05:32 PM
LT4BUD's Avatar
LT4BUD
There is like a snap-ring that holds the screen in place on the LT4....if you carefully remove the snap-ring you can remove the screen without damaging it.....I damaged mine..
I have been running without the screen for a couple of years now with no apparent problems.....gains...who knows....maybe 5-10hp??
Old Dec 30, 2004 | 05:33 PM
RIISITAS's Avatar
RIISITAS
Old Dec 30, 2004 | 06:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Isn't the sole purpose of the screens to srtaighten out the airflow? Just wondering
Old Dec 30, 2004 | 07:01 PM
LT4BUD's Avatar
LT4BUD
Yes....creates laminar airflow
....but on LT1/4 the intake system is fairly straight so the incoming air isn't as turbulent as on some of the f-body cars where the intake system is more curved....
..or so I have heard
Old Dec 30, 2004 | 08:05 PM
Blues77's Avatar
Blues77
Different case but interesting... on my friends TT stealth, we removed the "honeycomb" type of maf screen. It completely messed the car up, wouldnt idle or rev smoothly. Granted it was a different animal, but those screens do straiten out the air. When you start getting a higher volume of air flow like on a Turbo car, my guess is thats when the screen/s come into play.
Old Dec 30, 2004 | 08:48 PM
vstol's Avatar
vstol
Thanks, I want to confirm that there are 5 sensors in the LT4 MAF sensor, can one of you with an LT4 confirm that?
To MAF sensor screen
