2-piece timing cover -- will it fit?
Old Dec 29, 2004 | 07:27 PM
1986Z51's Avatar
1986Z51
Default 2-piece timing cover -- will it fit?
I'm planning on changing my timing chain & sprockets and am thinking about a 2-piece timing cover in case I change the cam in the future. Will a 2-piece cover clear the stock water pump? If so, any particular brand (I'm assuming it'd have to be steel)? I heard the L98 water pumps are short leg with limited clearance between the back of pump and engine block.
Old Dec 29, 2004 | 07:53 PM
Caboboy's Avatar
Caboboy
I just went thru this. I used a Cloyes 2 piece cover which is substantially more thick. My Milodon water pump didn't clear, but the old stock one did. I ended up using an Edelbrock hi flow rather than a stocko and it fit just fine because of the design of the cover plate on the back of the pump.
Reader's digest version: If you look at the cover plate on the back of your intended pump and it's flat, you're probably OK. If it has a molded shoulder around the perimiter by the bolts you may have problems. If you use a stamped steel timing cover, you're probably OK with either pump as well.
Are we confused now?
Old Dec 30, 2004 | 04:02 AM
randy814u's Avatar
randy814u
I had one i put on the motor, then went to put the stock 85 pump on and it was a good 1/4 inch from the block. So I pulled it off, and went with a one piece. I sure am glad it was out of the car and on a stand.
Old Dec 30, 2004 | 02:45 PM
1986Z51's Avatar
1986Z51
Thanks! My pump has the shoulder and bolts around the perimiter (it's only ~20K miles old so I don't want to swap it out). Think I'll try a 2-piece stamped steel cover then and revert to the original one if that fails.
Old Dec 30, 2004 | 10:50 PM
AKS Racing's Avatar
AKS Racing
I run the Comp Cams aluminum 3 piece cover and it clears the factory water pump without issue. Though you may have to shave a couple of the water pump backing plate bolt heads as I had to do on my '87. The 3 piece difers from the 2 piece in that the lower crank section is also removeable without dropping the pan.
As a benefit, the aluminum aftermarket timing covers make excellent cam walk bearing/bushing (forward loading of the cam) foundations. The factory covers and even the S/D stamped steel aftermarket cover flexed considerably when the cam bearing pushed forward.
I will make comment from my experience that everyone who uses these 2 piece or 3 piece covers winds up with oil leaks.
Aaron
Old Dec 30, 2004 | 11:08 PM
chriswtx's Avatar
chriswtx
I have the same set up as Caboboy. Cloyes 2 piece cover and Edelbrock hi flow water pump. Fits perfectly...
Old Dec 31, 2004 | 12:14 AM
AKS Racing's Avatar
AKS Racing
Chris,
Who makes the monoblade on your motor? It appears from your signature pic that yours has the original TPI plate, which is something I would like to retain. Cost please?
Thanks,
Aaron
Old Dec 31, 2004 | 12:17 AM
chriswtx's Avatar
chriswtx
That pic in my sig is before I changed to the monoblade. Airzona Speed and Marine monoblade. But It looks like you could take off their top plate and replace it with your stock one...Its a quility peice but has no ports for the PVC valve...which is ok for modded setups, but I did not no it when I ordered it. Still I like it even though it made no difference in HP on my car but I am pretty sure my small cam is the limiting factor.
To 2-piece timing cover -- will it fit?
