vortech/ATI question
Old Dec 29, 2004 | 09:23 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default vortech/ATI question
I had to trim the radiator shroud where the hose goes from the blower to the intercooler, just so the hood would close. The hood was pressing on the hose, and I didn't want it to collapse with the hood all the way shut. It fits now, but I think the hose still touches the hood, or at least is VERY close to it. My question is, how hot does the hose coming out of the blower really get, and is it going to cause problems if it is in contact with the underside of the hood? Thanks for any answers.
Old Dec 30, 2004 | 08:07 AM
LT1Vetteguy78's Avatar
LT1Vetteguy78
i have the same problem on mine but so far all is good.
Old Dec 30, 2004 | 02:00 PM
krivera's Avatar
krivera
Should be fine! no worries the head is not torching or anything.
Thanks Kevin
Old Dec 30, 2004 | 08:31 PM
gcrouse's Avatar
gcrouse
I had to grind away 1/2" of hood framework above my Procharger. The discharge hose / blower outlet was just a little too high.
You shouldn't have temperature problems, but I hope you're not restricting the flow by squashing the hose...
Old Jan 3, 2005 | 03:24 AM
Mo_Bandy's Avatar
Mo_Bandy
Worst case you may be seeing about 200 degrees ( probably less). You should see noo issues with temperature. Originally I had the same issue when I had an ATI intercoooler on my car. It does "squeeze" a bit but not enough to restrict the flow...
Mo
To vortech/ATI question
