An 88 has 9 fuel injectors? (one cold start)
OK..... I'm replacing the injectors, I guess I need 9 now. is the "ninth" one the same as the other 8? can I just order 9 that are matched?
The CS injector is unlike the other 8 and is no longer available.
If it is not functioning, you can either have it cleaned by Rich at Cruzin Performnace (link on my site) or eliminate it. If the latter, you can install an '89 ECM or live with hard cold starting.
