Wheel Swap
Old Jan 2, 2005 | 05:32 PM
mike_webb_tx's Avatar
mike_webb_tx
Default Wheel Swap
I have a chance to pick up a set of C5 wheels (2000) at a good price. I'd like to use the same set of wheels and sticky tires on both a C5 and also on a C4 that currently has the 16x9's all around. Can I use the 2000 wheels on a C4 with some spacers and longer bolts or a kit of some type; and can I run the 16-inch wheels with the spacers in place; or is just plain impossible? Thanks.
Old Jan 2, 2005 | 07:44 PM
FD2BLK's Avatar
FD2BLK
If you are just using them for the track then they should work fine with no spacers. I had 96 sawblades on my 84 (38mm offset) with no problems and they have the same 58mm off set as the C5. They will set in about 3/4 of an inch but it is just cosmetic
