New 3 Valve head for LT1?>>>>
Old Jan 4, 2005 | 11:08 PM
Raysur's Avatar
Raysur
Default New 3 Valve head for LT1?>>>>
http://www.barrygrant.com/pages/news...ticleid=sema04
It says pre '86 LT1 engines in this ad. Which is a typo. But in the magazine I read it said pre '96 LT1 motors. So we might have a new head for our cars.
Old Jan 4, 2005 | 11:26 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I'll never be able to afford it, but it sure is cool!!!
Old Jan 4, 2005 | 11:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Where does it say it's for the LT1, did I miss something?
Old Jan 4, 2005 | 11:36 PM
Raysur's Avatar
Raysur
http://www.barrygrant.com/pages/imag...Introsheet.pdf
Towards the middle. But it says pre '86 LT1 instead of pre '96 LT1
Old Jan 5, 2005 | 12:38 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
The new stock Ford heads on the new 05 Mustang are 3 valve heads. It is an interesting idea. Ford was able to generate as much power out of a smaller motor than we got out of 350ci. There are also several bolt ons coming that will boost the stang up to 400hp... this is going to get interesting!!!
What I'd like to know is how is the third valve operated. We have standard pushrod motors... so in order to move the valve... you'd need a different cam... different valve train all together... and where is the extra pushrod going to go? The block doesn't have provisions for it. Am I wrong? I'd like someone to explain this one to me...
Old Jan 5, 2005 | 12:44 AM
RadPolo96's Avatar
RadPolo96
You think thats cool, then look at this.
http://www.coatesengine.com/technology.html
Old Jan 5, 2005 | 12:47 AM
Curveit's Avatar
Curveit
Probably a "twin-arm" Y shaped rocker arm; I think some others use this method.
Old Jan 5, 2005 | 12:48 AM
chriswtx's Avatar
chriswtx
here is a pic, dont think its for reverse flow LT1's. note the "standard" small block chevys engines, vortec and pre-86'(meaning early LT1's, late 60's-early70's)
Old Jan 5, 2005 | 12:59 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
There is a company that has done a 4 valve head. I've never heard of anyone that has them. I think the valve actuation of the addt'l valve is similar, one pushrod and one special rocker that actuates two valves. The pic shows a typical 8 rocker per head setup (unless I'm missing something)
This raises an eyebrow for me. While each spring may be lighter, the pushrod/lifter/cam lobe is seeing two of them.
I would like to know for sure how the valve is actuated.
PS. The 4 valve heads go for 5 large.
Old Jan 5, 2005 | 01:08 AM
Zrxmax's Avatar
Zrxmax
That is cool ! Will be watching for more on that...
BTW... 3 valve motors have been around a long time... In 1984 Honda had 750 cc 3 valve V twin motors...
Not only that... they are still the only manufacturer that I know of that produced an oval cylinder design with 8 valves... 4 in and 4 out... that motor is a race motor placed in a NSR 750 cc bike... it actually had 2 cylinders... Iam not a Honda car fan... but they make some awesome motorcycles... and Indy motors... If only some of this technology would go into mass production... the hp per inch could take a big leap imho...
What else is out there ?
Old Jan 5, 2005 | 01:14 AM
VenkmanP's Avatar
VenkmanP
Not likely that anybody would spend the money to develop something like that for the small LT1 market.
Old Jan 5, 2005 | 03:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
www.araoengineering.com
I think this is what you're looking for. These guys are right up the street from me. Interesting piece. Used to be called Dominion heads, a marketing company used years ago. Link should work now!
Old Jan 5, 2005 | 01:13 PM
shotchkiss's Avatar
shotchkiss
GM has been talking about 3 valve heads for several years now, here's some brief info I found on their site http://www.gm.com/automotive/gmpower...OHV_3valve.pdf
Old Jan 5, 2005 | 03:34 PM
Strick's Avatar
Strick
I wonder how the electro controlled valves are doing? No cam, rockers, pushrods or lifters, just a computer to activate the opening and closing of the valves. Heat buildup seems to be the biggest problem of the solenoids that move the valves.
Old Jan 5, 2005 | 04:17 PM
bogus's Avatar
bogus
Ford is working hard on it... give it 5 years and a working prototype will be displayed.
Old Jan 5, 2005 | 08:00 PM
95wht6spd's Avatar
95wht6spd
It would be nice to know if these are for LT-1's or LT1's. It should either say "pre 92 or 96" I would think.
Old Jan 5, 2005 | 08:37 PM
ztrips's Avatar
ztrips
Actually pnuematics are a much better way to do this, and it's already been done. F1 cars use them. You can have them too for a million bucks.....
Old Jan 5, 2005 | 08:42 PM
siggy_freud's Avatar
siggy_freud
http://www.araoengineering.com/pakag...%20High%20Port
check out the bottom of this page.
Old Jan 5, 2005 | 10:59 PM
RatC4's Avatar
RatC4
Originally Posted by Bigvmaxx
Not only that... they are still the only manufacturer that I know of that produced an oval cylinder design with 8 valves... 4 in and 4 out... that motor is a race motor placed in a NSR 750 cc bike... it actually had 2 cylinders... ?
It was actually a four cylinder. They wanted the high rpm volumetric efficiency of a v-8 but the racing class way limited to four cylinders. Thus you have four cylinders with the valve area of a v-8. Honda did a limited run of the NSR750 for the street. I believe it cost in the ballpark of $60k new and this must have been fifteen years ago.
The Coates rotary valve setup is the one that looks very interesting. No valve stem to impede airflow and no risk of valve float.
To New 3 Valve head for LT1?>>>>
