door switch going crazy
Old Jan 5, 2005 | 02:00 PM
kman0066's Avatar
kman0066
Default door switch going crazy
my door ajar light and my interior lights go crazy while i'm driving down the road. It also keeps setting my alarm off when I leave the car and the alarm sets. So looking at the store I find 2 different switches. Which one do I need for my 93 Coupe.
87-95 RH/LH DOOR ALARM SWITCH & PIGTAIL
or
88-94 DOOR AJAR SWITCH
I thought these were one and the same?
Old Jan 5, 2005 | 03:19 PM
Corf's Avatar
Corf
The door ajar switch is the guy you can see when you open the door. The door alarm switch is inside the door on the back of the door lock cylinder.
Old Jan 5, 2005 | 03:36 PM
ZZZASY's Avatar
ZZZASY
The lighting situation would be the door ajar switch.
ZZZASY
Old Jan 5, 2005 | 03:52 PM
Corf's Avatar
Corf
ZZZASY
Old Jan 5, 2005 | 04:19 PM
VenkmanP's Avatar
VenkmanP
or
I thought these
Before replacing the switch you should make sure it and the door are properly adjusted.
Old Jan 5, 2005 | 04:53 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
The "door ajar switch" can be adjusted. It's a screw type thing. I've had to adjust mine a couple of times. Just grab the tip and turn, no tools required.
To door switch going crazy
