The Super comps are Glowing??
Old Jan 6, 2005 | 03:27 AM
kpforce1's Avatar
kpforce1
Originally Posted by MaxLean
Top ring gap of .040"??? That's REALLY big. Ring gaps on a 4.0xx" bore are usually .016"-.022", larger of you plan to use a power adder. At .040" I'd expect alot of blow by and oil consumption. At any rate, 10.5-11.0:1 is a bit high for iron heads, so you may not be able to run the ideal amount of timing. It really depends if the engine is detonating at that amount of timing. This is assuming, of course, your running 91 octane or higher.
I thought .040" seemed large to but under higher RPM's and some stress the heads of pistons were commin right off when gapped .016-.022"...i'm pretty sure this info came from a speed pro tech...don't hold me to it though. Why would a compression ratio of 10.5 or so not be able to run the ideal timing with iron heads? I run nothing but 91+ and usually octane boost 1 out of 3 tanks run through it.
Old Jan 6, 2005 | 03:30 AM
kpforce1's Avatar
kpforce1
A little off topic but I'm also wanting to run dual exauhst...i was thinking 3" with my setup (with H pipe). the only problem is that I have a new set of flowmaster 50 series delta flow muffs for the vette (300$) that have 2 and a quarter inlets i think. What should I do about this delima??
Old Jan 6, 2005 | 03:48 AM
MaxLean's Avatar
MaxLean
The reason you can run a higher comp ratio with aluminum heads has to do with its thermal conduction properties. Combustion temps run higher on an iron head because of this.
Old Jan 6, 2005 | 03:51 AM
MaxLean's Avatar
MaxLean
Why, you're gonna have to ditch the flows of course.
No point in considering adaptors, if that's what you're thinking.
Old Jan 6, 2005 | 04:04 AM
kpforce1's Avatar
kpforce1
Well, the 3" inlet standard version cost around 70$ i think, half of what one of the others does. Looks like i'll be switching them...lol
Old Jan 6, 2005 | 04:06 AM
kpforce1's Avatar
kpforce1
so what kind of power do you think that my setup will put out at the fly tuned properly with 3" duals MaxLean??
Old Jan 6, 2005 | 04:14 AM
MaxLean's Avatar
MaxLean
Pretty high, actually. Maybe 420-440 chp?
Old Jan 6, 2005 | 08:45 AM
runner140*'s Avatar
runner140*
Default Sounds like it could be......
Your timing could be off and could be throwing raw gas. I saw a post about your dist. of a tooth also seems a place to start. (amoung others)
Old Jan 6, 2005 | 10:04 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I agree with comp, it's running lean. That's why the coolant temps are high too.
