Cylinder Heads
Old Jan 5, 2005 | 11:43 PM
John A. Marker's Avatar
John A. Marker
Default Cylinder Heads
I have been researching heads (and threads associated) on the forum for awhile. I have come to the conclusion that with an older C4 (85 L98) that going above 180 CC intake without major cam or engine mods kills the L98 torque. Based on that assumption I am looking at the AFR 180 heads since they are fully ported out of the box. I am not looking at a magical HP number or torque number. The basic plan would be AFR 180 heads, SR base manifold and going with a front "Y" pipe from exhaust manifold to cat that is 2-1/2". I already am running 1.6 and 1.5 RR (which I would switch to the new heads), Plenum is ported and a 52 mm throttle body. Any suggestions?
BTW - a good head comparison chart that I found is located at:
www.users.erols.com/srweiss/tablehdc.htm
Old Jan 6, 2005 | 12:00 AM
Nathan Plemons's Avatar
Nathan Plemons
Personally I would avoid AFR heads, they are known to have many quality control issues. I've seen some of them first hand, I wouldn't buy them.
I'm also not a huge believer in the split rocker ratio. If you increase the amount of air coming into the engine it only serves to reason that you would need to increase the exhaust going out. If you need to tweak the lift or duration of the intake relative to the exhaust you can do so when selecting the camshaft and then you only have to run one size rocker.
Old Jan 6, 2005 | 12:11 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Why not get a set of 113s and have them worked by a competent porting service? I believe this is all most folks will ever need for the street. I have fully ported LT1 heads and they outflow stock LT4 heads by a ton. They also retain good velocity and low end response is almost overkill. I'm quite pleased with my head work.
Old Jan 6, 2005 | 01:18 AM
comp's Avatar
comp
link not working
Old Jan 6, 2005 | 01:24 AM
cv67's Avatar
cv67
St. Jude Donor '05
Depends what you want to spend. Ported 113's would work well: for about a grand you should be able to get a real valve job and hopefully flow 240-250. AFR 180's work incredibly well in my opinion. Probably set you back a few more bills; you get the idea. Everyone will have their favorite as you will find out. That's what the board is for! There are other brands out there but I can't comment on them due to the fact I haven't tried them. Good Luck
Old Jan 6, 2005 | 03:26 AM
pablocruise's Avatar
pablocruise
You probably already know it but in case someone doesn't,
AFR has unported, 70% ported or fully ported versions.
Have them machine provisions for the temp sensors. Sometimes they forget.
Of course a 4th option is porting by hand by a really good and experienced person.
Are ya keeping the EGR?
There is a internal to external EGR passage change that occurs in 86-87 and you would have to draw the gas from #8 header primary(would mean obtaining 87 up exh manifolds or hooker 2149's)
D113's and AFR's don't have internal EGR because they are aluminum.
Old Jan 6, 2005 | 03:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
I believe AFR has a head specifically for the L98. The power gains are substantial
Old Jan 6, 2005 | 07:17 AM
88BlackZ-51's Avatar
88BlackZ-51
What about the TFS head. Good head for the price.......Flows 254CFM/195CC/62CC.
Old Jan 6, 2005 | 08:09 AM
MrNuke's Avatar
MrNuke
I have an '85 vette with stock internals (cam/shortbock/etc..)
I am knocking on 11's doors with the car with a Superram/LPE 1 5/8" headers, dart iron eagles (ported) (200cc runners), 1.52rrs, Dana44 w/3.45 gears, and bolt ons.. (And114K mileson the engine)..
Did notice abit of low-end torque loss after the header/heads swap, but it came back once I tuned the car with my chips, or the ecm relearned stuff. Either way it IS running great..
Next stepis o upgrade to a roller cam/block when I chose to replace the shortbock in the future.. That should be good for another 30-40HP and higher rpm otential (game's over around 53-5400rpms with the stock cam/lifters)
Old Jan 6, 2005 | 02:38 PM
siggy_freud's Avatar
siggy_freud
I am running TFS 190's on my 355 with the TPI. I absolutely love them (other than the fact that I have to redo the head gasket lol). I noticed a great power increase over my stock heads.
Dont be totally taken by AFR's numbers. They come ported from their factory. A set of TFS heads with the same port job will outflow AFR's. Just dont go too big with the runner sizes. You'll kill your velocity thus hurting your bottom end. 190's is as big as I'd go on a TPI on a 350. Larger displacement engines (383's, 400+'s) like a bit more runner size depending on their cam and intake setup (superram, mini ram, stealth, etc).
Old Jan 6, 2005 | 02:56 PM
comp's Avatar
comp
Originally Posted by comp
link not working
still not ,,anybody else open it ????
Old Jan 6, 2005 | 08:16 PM
1986Z51's Avatar
1986Z51
http://users.erols.com/srweiss/tablehdc.htm
One of the funny links that's happier without the www.
Old Jan 6, 2005 | 08:28 PM
1986Z51's Avatar
1986Z51
Originally Posted by MrNuke
I have an '85 vette with...
dart iron eagles (ported) (200cc runners)...
How do the Dart Iron Eagles fit, do spark plugs fit without having to bend the headers? Did plugs fit with stock exhaust manifolds (if you tried this)? I've been looking into upgrading my iron heads and have been leaning towards Darts, particularly the Iron Eagle Platinum when the 180cc are available. But I'm also learning that aftermarket heads (depending on brand) can have issues with spark plugs interfering with exhaust tubes.
To Cylinder Heads
