C4 Door Molding Help Needed
Old Jan 6, 2005 | 05:39 PM
C4BOB's Avatar
C4BOB
4th Gear
Default C4 Door Molding Help Needed
Ware Can I Buy The Plastic Door Molding Push Through Clips That Break Off When You Remove The Molding They Are Held To The Molding With 2 Small Philips Screws I Also Need The 2 Sided Tape On The Molding Also Gm Cant Find A Part Number Thanks C4bob
Old Jan 6, 2005 | 06:16 PM
ABNVET.I's Avatar
ABNVET.I
I found them at autozone. They have a whole rack of trim parts and fastners I think I even seen the tape there.
Old Jan 6, 2005 | 08:01 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
The part number I have on the clips/screws is #88891647. Sorry I don't have the # on the trim. It didn't come packaged.
Old Jan 6, 2005 | 10:56 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
According to my dealership you cannot get these parts you need separately. If they are at Auto Zone you lucked out. Try a Vette recycler and see if you can pick up a damaged one to rob parts off of. They are of little or no value to them. I used 3M 1/4 inch windshield installation ribbon to replace the two sided tape. Worked like a charm.
To C4 Door Molding Help Needed
