Coolant Temperature Sensor
Old Jan 6, 2005 | 11:39 PM
Epyon127's Avatar
Epyon127
Default Coolant Temperature Sensor
I broke the CTS on my car while removing the serpentine belt. I am wondering if anyone has replaced theirs? I believe it is a "screw out' will this unload my coolant? Also where should I look to buy and about how much? Thanks for any info.
Old Jan 7, 2005 | 12:32 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will need to drain some coolant before removing the sensor.
Try Contemporary Corvette (link on my site) if Auto Zone doesn't have the sensor.
Old Jan 8, 2005 | 01:05 AM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
i just bought one for ten bucks at checkers. it even came with a new connector. brilliant.
Old Jan 8, 2005 | 09:07 AM
redbullapril23's Avatar
redbullapril23
yes the coolant needs to be drained from everything above the sensor thus making sure gravity doesnt screw you...remember the opti is right under what you are doing!
also drain from the block not the radiator
good luck!
thanks alot
your friend
Sean
email me for all your ceramic coating, powder coating, and deep cryogenic processing needs!
Header special- Long tube headers Coated inside and out for $188! Includes 3 yr warranty, limited lifetime rust warranty, and all preping!
Slimshaby@mindspring.com
Old Jan 8, 2005 | 09:50 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Also put rags under it so that you don't get anything dripping on the good old Opti. VatoZone should have it.
Old Jan 8, 2005 | 11:46 AM
Brimis's Avatar
Brimis
Auto Zone or Advanced Auto.
To Coolant Temperature Sensor
