Leak Down Test
Old Jan 7, 2005 | 08:28 AM
ittlfly's Avatar
ittlfly
Default Leak Down Test
The title says it all. I need the proper and exact procedure for doing a complete test.
Thanks is advance.
Old Jan 7, 2005 | 09:35 AM
Pete K's Avatar
Pete K
1) Warm engine
2) remove all plugs
3) put piston you are checking at tdc
4)screw in fitting and put 100 psi air
5) Read the guage and log the number
Motor may try to roll over with all plugs removed. Some guys like to do 1 at a time but it is harder to roll motor over (by hand) to put piston at tdc.
Edit: tdc on compression stroke to ensure both valves are closed.
Old Jan 7, 2005 | 10:59 AM
Corvette0096's Avatar
Corvette0096
Might need to smack the top of the valves to with a soft face hammer.
In the TDC On the compression stoke will the air is on.. This get a good seal on the valves.
Old Jan 7, 2005 | 07:50 PM
ittlfly's Avatar
ittlfly
Originally Posted by Pete K
1) Warm engine
2) remove all plugs
How long should a cyl. hold air if all is well????
Old Jan 7, 2005 | 08:17 PM
ralph's Avatar
ralph
It's not time sensitive. the tester will have two guages: one showing applied pressure and the other showing the cylinder pressure. If you use 100psi source, then the leakdown % will be the difference between the source and the cyl.
Old Jan 7, 2005 | 09:07 PM
ittlfly's Avatar
ittlfly
OK I got it now..Thanks..
To Leak Down Test
