I'm running 125 shot right now with a stock tune without any problems. But I'm getting a chip made this week and I will need to pull timing because I know that the new chip will be higher then the stock was.
I don't want to use a MSD digital to control all my timing because of reliability issues. So my question is -- Is there anything I can buy that will work for pulling the timing when on the spray and will still let the ECM run things like it is now when I'm not?
Can this be used on my LT1 to pull the timing that I need to pull only on the spray? And can it be used on my car without adding a digital box like a MSD6 or 7?
