Will SS braided brake lines really make a difference...
Old Jan 8, 2005 | 04:51 PM
Southern Comfort's Avatar
Southern Comfort
Default Will SS braided brake lines really make a difference...
on my 85?
No ABS
Old Jan 8, 2005 | 06:34 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Let`s see less flex, looks prettier, more expensive. That pretty much covers it, I think.
Old Jan 8, 2005 | 06:38 PM
Southern Comfort
well my lines are stock and original. And I have noticed longer braking periods. new rotors and pads and MC. So is that a yea or nay.
at 100 bucks not really wanting pretty.
Old Jan 8, 2005 | 07:00 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by Southern Comfort
well my lines are stock and original. And I have noticed longer braking periods. new rotors and pads and MC. So is that a yea or nay. at 100 bucks not really wanting pretty.
Advantages of SS are the lines are firmer and will not "ballon" or expand when pressure is applied. The results is a better feel (feedback) on the pedal. Will you notice the difference? This is likely if your driving (braking) style is very aggresive, or your original lines are limber. The later is not something you can see or check for. And you won't stop any sooner....
IMHO, I installed SS lines on my Corvette because I want the added insurance that the STOP pedal is best equipped to preform its mission. I also change the brake fluid once a year.
-JRC-
Old Jan 8, 2005 | 07:01 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Just make sure and get the ones with the clear plastic cover. A lot easier to keep clean.
Old Jan 8, 2005 | 07:04 PM
nitronick's Avatar
nitronick
Does the SS ones have any problem with swelling closed like the stock rubber ones do?
Old Jan 8, 2005 | 10:06 PM
vader86's Avatar
vader86
I have a set on mine, but didnt try them out before I put on the C5 brakes.
I just got them because they will stay firm and should last a good long while.
Old Jan 8, 2005 | 11:22 PM
REW89's Avatar
REW89
We have used use SS brake lines on our race motorcycles for years. They give bikes a lot more whoa.... I think if you did a lot of performace driving you would really tell a difference.
MTCW BOb
Old Jan 9, 2005 | 01:34 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If your stock lines are in good condition, then don't buy the SS lines. The only useful advantage they have is being more firm. And that attribute is pretty overrated.
Old Jan 9, 2005 | 01:37 AM
CentralCoaster
The purpose of this is to keep grit from getting into the SS braids and chewing up the teflon line. The teflon hose is very brittle and fragile, and what I've seen, is the factory hoses are way more reliable.
Old Jan 9, 2005 | 02:24 AM
nitronick's Avatar
nitronick
And that leads me back to my other question regarding the rubber lines. I don't know so much about Corvettes, but I have had numerous GM vehicles (personal cars to school buses and everything in between) over the years where the inside of the rubber line had swelled shut. And one of two things happened.
1. No amount of pedal pressure would allow fluid through to activate the caliper or,
2. wouldn't allow the pressure to release, keeping the caliper constantly applied.
Both of these instances causes the vehicle to pull to one side. The first would be when applying braking, because you really only have one side actually working. The second would be a pull all the time. And the second one tends to make the caliper, rotor and wheel REALLY HOT! Even if driven only a short distance! It will literally boil water.
So, after all this, my question. Would the steel braided, teflon lines have this problem?
Old Jan 9, 2005 | 04:05 AM
amm0bob's Avatar
amm0bob
From: The last place on earth to get cable... Sacramento
Braided lines are more reliable (if clean)... the rubber lines are not just rubber though... and they WILL last many years before failure. But any rubber that is 12 years old is subject to failures...
Sometimes you're lucky, sometimes you're not... for a measily hundred bucks or so put new lines in for safety's sake.
Old Jan 9, 2005 | 09:57 AM
c4cruiser's Avatar
c4cruiser
I have braided lines on both my 92 and 87 autocross car. There was a difference in pedal feel after I had installed them, but as mentioned, this was after replacing the original lines.
I paid less for the Earl's braided lines at Summit Racing than the cost of AC Delco rubber hoses.
Old Jan 9, 2005 | 11:31 AM
85blkrose's Avatar
85blkrose
i plan on going with ss lines. being my car is 20 yrs old and want to clean up the wheel well for show purposes.gonna kill 2 birds with one expensive stone .
Old Jan 9, 2005 | 04:27 PM
CentralCoaster
Good point. The teflon lining retains its shape better, won't swell open or shut like a worn out stock line. Long term, i don't know. The SS lines are stiffer and more likely to break off at the crimp fittings though. This is why they initially had such a hard time getting em DOT approved. you almost need longer break lines to ease the force on these fittings, but then you run the risk of the lines rubbing on the tire or suspension at full lock, and they don't test fit each make and model.
Also, keep in mind here, that these guys are usually comparing 15-20 yr old rubber lines with new SS lines.
Old Jan 9, 2005 | 05:04 PM
JrRifleCoach
Not heard of this problem before this. The aircraft industry has used these for the last 50 years in more critical applications. Thats why I buy from Earls Supply. They do business selling AN hardware using aircraft quality standards.
Old Jan 9, 2005 | 05:36 PM
87SAM's Avatar
87SAM
So which brands of SS lines have the clear plastic cover?
To Will SS braided brake lines really make a difference...
