fuel pressure switch question
Old Jan 9, 2005 | 03:26 PM
I Hate Rice's Avatar
I Hate Rice
Default fuel pressure switch question
Could someone tell me what this little fella is. The little male fitting coming out of the passenger side fuel rail. Because I'm mounting a fuel booster pump for my nitrous kit and theres not a whole lot of room to mount it next to the fuel filter so if I could mount the fuel pressure safety switch somewhere else...like the fuel rail...i'll be in business. Here is a picture of what I'm talking about...btw 92' lt1.
Old Jan 9, 2005 | 04:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's the Schraeder valve to which you might attach a fuel pressure gauge to check fuel pressure.
If you use that "port" for your NOS hookup you will lose fuel pressure diagnostic capabilities unless you have a dash (or pillar) mounted fuel pressure gauge.
Old Jan 9, 2005 | 05:55 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
If you're running under a 150hp shot, I would update the stock pump in the tank and not bother with an inline. Just my $.02
You can hook your nitrous fuel line right there on the fuel rail and with a updated pump you will be fine. I have been spraying 125hp for 2 years with my stock 93 pump and have no problems. Somewhere in my house I do have a new welbro pump that I need to put in though.
To fuel pressure switch question
