impala head gaskets
Old Jan 10, 2005 | 10:57 AM
1996man's Avatar
1996man
Default impala head gaskets
has anyone put these on a lt4? i think i remember reaing that some lt4 owners have. how much power does this give you? is it safe? what makes them give you more compression? please help fill me in here
Old Jan 10, 2005 | 11:05 AM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Default Impala Head Gasket.
To my memory, Impala head gaskets were .029 think. Felpro LT1 units are 0.039 and I believe factory is slightly thicker than the Felpro.
Someone may want to verify the factory thickness for comparison.
Old Jan 10, 2005 | 11:20 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Initial thickness is not as important as the final (crush) thickness.
Anyone know those numbers?
Larry
code5coupe
Old Jan 10, 2005 | 03:59 PM
1996man's Avatar
1996man
is there any danger is having them that thin? how much power does it add?
Old Jan 10, 2005 | 04:07 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I'd like to use the Impala head gaskets on my 92 to bump up compression. My heads have been decked a couple times and I'm not sure where my compression actually is now ...
I'd also be interested in knowing what the actual change in compression would be by using this thinner gasket ...
Old Jan 10, 2005 | 06:42 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
These ARE the crush numbers. And factory LT1 Corvette gaskets are .049. I would assume the LT4s are the same.
Old Jan 10, 2005 | 08:38 PM
Atok's Avatar
Atok
You need to be careful of the quench area also. You get it too tight and it'll be prone to detonation.
Old Jan 14, 2005 | 12:18 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I "THINK" atok meant the opposite. I'm pretty sure he did.
May be positive he did. This is a case where less is more......
Old Jan 14, 2005 | 08:25 PM
96GS#007's Avatar
96GS#007
I've been running them for a couple years. Imp gaskets are .029" compressed. They'll bump your static CR to 0.4, give or take .1 as I'm going from memory
Unless you've performed other mods already, pistons on stock LT1s and LT4s are generally between .025 and .030 in the hole. Therefore, adding the thinner gaskets helps quench.
It won't net much hp...5-10 depending on specifics of the setup...but since you have to install head gaskets anyway, "why not?"
You may or may not need to tweak your timing map, again depending on specifc setup and parts.
Old Jan 14, 2005 | 09:50 PM
Topload's Avatar
Topload
with 96GS#007....have the Impala gaskets on my mildly modified LT1 and have been running pump gas for several months without any problem - and have been beating on her pretty good - she seems to be enjoying the punishment.
To impala head gaskets
