GM847 camshaft
Old Jan 10, 2005 | 05:02 PM
1996man's Avatar
1996man
Default GM847 camshaft
who all is running one of these? i am thinking about getting the dragon camshaft that boulderlt4 has but i had the GM847 cam suggested. i tried looking on a few GMPP sites but couldnt find it. who all is running it with what mods? what kind of power are you putting down?
Old Jan 10, 2005 | 05:17 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I'd like to know this too. I know Jim Mason (GS???) is planning on installing this cam very soon. His insight has got me thinking... but I'm already set up for the hotcam.
Old Jan 10, 2005 | 06:47 PM
chriswtx's Avatar
chriswtx
Old Jan 10, 2005 | 07:05 PM
LT4BUD's Avatar
LT4BUD
Originally Posted by 1996man
i tried looking on a few GMPP sites but couldnt find it.?
http://www.gmgoodwrench.com/perfpart...on=ep#12370847
Old Jan 10, 2005 | 07:08 PM
LT4BUD's Avatar
LT4BUD
Plus I thought it was the 846 cam Jim Mason was going to use?????
Listed right above the 847...
Old Jan 10, 2005 | 07:16 PM
FD2BLK's Avatar
FD2BLK
I have never used this guy but have heard great things about his camshaft/head packages and several of the F-body guys are using him. Lloyed will also answer any questions you may have about the 847 with your set up.
Lloyd Elliott
972-617-5671
NightTrain66@msn.com
http://web.camaross.com/forums/showt...+elliott+heads
Old Jan 10, 2005 | 07:32 PM
96GS#007's Avatar
96GS#007
Correct, I'm running the 846 cam. IMO, the 847 is a touch too big for a 350 that sees street duty, especially if you want decent street manners and you don't want to lose low end torque. In my case, I've been known to drive 7+ hours to events . As a result, dealing with cam surge while cruising along in 6th gear and 1800rpm for most of that 7 hours wasn't acceptable to me..
The 846 has a couple more degrees of duration than the HOT Cam and more lift (.543/.563 vs .525/.525). I have just over 900 miles on the new engine and I'm very pleased with it so far. My part throttle tuning is basically complete. The plan is to hop on the dyno in the March timeframe for WOT tuning. I'm expecting to be around 375rwhp @6500rpm (previous with the HOT Cam was 363 @6400). Gotta get WOT tuning taken care of as I'll be teaching and driving at a PCA driving school in April
Personally, I think the 846 cam is the best kept GM secret ever.
Old Jan 10, 2005 | 08:43 PM
Zix's Avatar
Zix
I've run the 846 cam for about 2 years now in my LT4 and it performed great. I'm taking it out now because of the 383 that's going in. I've seen some F-bodys using the 847 cam and they have some impressive numbers, but I've never seen a dyno chart so I really can't tell where the power is actually being made. The cam in BoulderLT4's car makes great peak power, but take a look at it lower in the RPM range...for street driving it may actually be a bit slower, unless you want the engine to be revving all the time. I'd like to see that cam in a 383+ or with a better set of heads backing it up.
Old Jan 11, 2005 | 12:04 AM
ENJ's Avatar
ENJ
I happen to have that cam in my car. I still need a good tune because my tune is for the LT-1 Hot Cam. Car ran a 11.87ET at 117MPH on street tires (Yoko's) but the next run broke the Transmission (ZF). I have not dyno'ed the car, but it's making power. I have a 383CID w/stage 3 AFR ported heads & shory headers & 1.6 RR which creates lift up to .574/.596 & 4:11 rear gear. I drive the car to work sometimes & actually don't have the cam surge most talk about. Planning on moving to long tubes, 3 in exhaust & a good tune. Presently using Borla's.
Old Jan 11, 2005 | 12:49 AM
tjwong's Avatar
tjwong
Lloyd Elliott
972-617-5671
A friend of mine is running the 847 cam in his 95 Corvette with a 396 stroker from MTI. The cam was suppose to be a MTI custom grind but from all indications we have its a 847 which is ground by Crane for GM and or MTI. My friends car absolutely screams, it was to have made 550hp on their engine dyno, and when I last rode in this car it felt like it as well. The cam did howver exhibit cam surge on the bottom end. It didn't like loaffing around at 1400 to 1800 RPM and cam surge was highly evident during my test drive with the car. It did however scream when he put the pedal to the metal as promised.
Old Jan 17, 2005 | 12:46 PM
redbullapril23's Avatar
redbullapril23
ok do you think I could put the 846 cam in my 1996 if....
I go to stg 3 ported lt4 heads, 1.6 rrs, lt4 intakes ported to match?
along with my current mods, hedman lts, muffler elims, under drive pullies, ac delete?
thanks alot your friend
Sean
Old Jan 17, 2005 | 12:50 PM
crheinish's Avatar
crheinish
Sean
Old Jan 17, 2005 | 12:54 PM
redbullapril23
just realized something do i need an electric water pump to run this?
Sean
Old Jan 17, 2005 | 12:58 PM
crheinish's Avatar
crheinish
Sean
No, you can use the stock setup.
Old Jan 17, 2005 | 01:14 PM
redbullapril23
awesome!
what type of rrs with this cam/head combo?
1.6 or 1.7 or stock lt1s
also do you think the ls1 beehive springs will work?
Old Jan 17, 2005 | 01:15 PM
87Z-ya's Avatar
87Z-ya
The 846 and 847 cams are made by crane 109831 and 109841 are the part #'s I believe. I have been running the 109831(846) for several years now and love it.
Old Jan 17, 2005 | 02:15 PM
redbullapril23
kool what springs/lifters/RRs are you all running with this cam?
To GM847 camshaft
Old Jan 17, 2005 | 10:35 PM
87Z-ya's Avatar
87Z-ya
With 1.5's the 109831 lift is only/.509_.528. I run the lt4 springs and they are fine.
Old Jan 18, 2005 | 09:35 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
I plan on installing my new 383 with the GM847 in two weeks. This will be my first motor swap so I hope all goes well. I post dyno sheet by mid/end FEB...
Old Jan 18, 2005 | 10:59 AM
redbullapril23
so it would be better to run 1.6s?
or would it be too much lift?
Sean
