Help me help out my buddy here.
Old Jan 11, 2005 | 01:30 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Help me help out my buddy here.
This poor guy has rebuilt his motor twice now, and not making any progress. His dad is actually doing the work, he's an old school diesel mechanic.
Both times, it's broken the ring lands or rings on 3 of the pistons, on the same cylinders. I try to give him advise based on the info he gives me, but he's not as knowlegable as me.
Think it could be out of round cylinders? Taper on the cylinders? Warped block? Warped deck surface allowing coolant into those cylinders every time? Maybe his dad is just a numbskull?
Any other ideas? It's a sweet ride, we used to go cruising in college, but as of late, it's just sitting under a canopy near Angel's Camp. The last time he had it running it had crazy blowby, would cover the underside of the hood with oil droplets. Not sure if it was steam also or not, but I told him to tear it down after I saw that, and that was one rebuild ago and we're in the same shoes.
Old Jan 11, 2005 | 01:33 AM
bogus's Avatar
bogus
take the block to a good machine shop and have the cylinders bored out. And use a torque plate. Something is outta wack.
Old Jan 11, 2005 | 01:35 AM
cv67's Avatar
cv67
St. Jude Donor '05
Ring gap
Old Jan 11, 2005 | 01:43 AM
CentralCoaster
Ring gap was my suspicion the first time they tore it down, but he insists that wasn't the problem.
This is a 347 cube '57 Pontiac with matching numbers btw.
How he was able to factor out ring gap I have no idea.
Old Jan 11, 2005 | 01:46 AM
comp's Avatar
comp
cast piston's ??? any sign's of detention?
Old Jan 11, 2005 | 01:48 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by CentralCoaster
This poor guy has rebuilt his motor twice now, and not making any progress. it's just sitting under a canopy near Angel's Camp.
NEAR Angels Camp? Like where near Angels Camp?
Old Jan 11, 2005 | 02:37 AM
CentralCoaster
Arnold.
You familiar with the area? I love it up there. Not much flat ground to do wrenching on though.
Old Jan 11, 2005 | 03:05 AM
JrRifleCoach
Arnold.
Your right, not much flat ground. Unless you have carpet in the garage. Arnold..... 15-20 minutes from here.
Old Jan 11, 2005 | 08:18 AM
jfb's Avatar
jfb
Is there a ridge at the top of the cylinders? Ask him what the ring gap was measured at before he installed the rings. Did he use the original pistons? What is the measured piston to cylinder gap? What is the clearance between the rings and the piston ring slot? Did he rod the oil hole in the connecting rods? Did the engine run at the opening temperature of the thermostat? or did it overheat?
Old Jan 11, 2005 | 08:38 AM
rick lambert's Avatar
rick lambert
Hope he used a ridge reamer! if he didn't-the ridge will break em forever.
Old Jan 11, 2005 | 09:10 AM
kabnvtt's Avatar
kabnvtt
That is about 25 miles east of Bear Valley. Man that place gets some fricken snow fall. Robert Conrad lives in Bear Valley and coming down from there into Arnold he got into a pretty bad wreck (Dui). Bad highway.
Old Jan 11, 2005 | 10:40 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
This would be my guess too, especially if it's the top ring he's breaking. Not likely ring gap in an old Poncho unless the rings are oversize for the bore. Have him check and be sure the ring lands are uniform all the way around the piston. Take an old ring piece and use it as a feeler gauge to look for tight spots. Did they clean the lands out good? Carbon will build up in there. Also, make sure he's using a top quality ring compressor when installing them. The old band style compressors are practically useless.
Old Jan 11, 2005 | 01:48 PM
olman's Avatar
olman
With his dad being an ol diesel mechanic, I'm sure the block was prepped right and rings insalled correctly. That said, I'd look at the compression ratio and detonation. In '57 the gas was a lot better than it is now with 100 plus octane ethyl being available at every station. High compression ratios were very common. Detonation can do bad things to pistons and rings, even rods. Ask me how I know? I'm tone deaf and can't hear the ping, so I've had the experience with todays lousy gas. Used to street race a new 57 Super Chief when I was a kid. Nothing then would touch it.
Old Jan 11, 2005 | 05:39 PM
CentralCoaster
Thanks for the pointers guys, I'll see if I can't enlighten them a bit. I have a feeling they'll be holding off on work awhile with all the snow. He does have it parked in a canvas garage, not a tarp.
I wish I could get some time to run up there and help him out with it. His dad wants to say hell with it and drop a SBC in there. Sacrelige!
To Help me help out my buddy here.
