Spring stiffness
Old Jan 12, 2005 | 11:53 AM
RED LT4's Avatar
RED LT4
Default Spring stiffness
Does any one know what a yellow cade would mean on a set of springs? I know that it is a stiffness code but what stiffness? I have a 96 with the f45 and it is too soft. Shocks are needed to be replaced as well
Old Jan 12, 2005 | 01:45 PM
bogus's Avatar
bogus
http://www.vettenet.org/susp_chart.html
Old Jan 13, 2005 | 02:12 AM
froggy47's Avatar
froggy47
I believe yellow is the softest for a 96, it's what I have on my base suspension.
You may find if you up the shocks & bars that the springs will be good, that's how I went. 30 solid f, 26 solid rear, qa1's set near max mine does not lean much.
Old Jan 13, 2005 | 11:42 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
I'm not sure about any color codes, but all of the springs will have a two or three digit code on them. Using the chart that bogus posted as a starting point, over the years of working at a Corvette store, I have coordinated all spring rates with their codes.
Old Jan 13, 2005 | 04:48 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Springs are the last thing you want to change. Even race cars, in general, don't use as stiff of a spring as they did in the old days. Get your bars and shocks right, and you'll probably love it, without sacrificing much ride comfort.
To Spring stiffness
