Performance MAF?
Old Jan 13, 2005 | 09:02 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default Performance MAF?
Are performance MAF sensors a waste of $300?
Roger
Old Jan 13, 2005 | 09:07 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
yeah... you can save yourself some $$$ by porting and de-screening yours
Old Jan 13, 2005 | 09:20 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default maf $$$$$$
How do you port a MAF?
Roger
Old Jan 13, 2005 | 09:21 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default maf question
Roger
Old Jan 13, 2005 | 09:27 PM
LT4BUD's Avatar
LT4BUD
I just ordered one of these......don't know how it is going to work yet....
http://www.madvet.com/shop?frame=1.230.677
I have "heard" some negative things regarding the Granetelli units....
Old Jan 13, 2005 | 10:27 PM
vader86's Avatar
vader86
I wouldnt ever spend that much money on a MAF, all you need to do is remove the front and rear screens on yours, if you have an L98. I would not remove the heat sink fins inside.
If you have an LT1, leave the damn thing alone.
The 'performance' MAFs are just a gimmick to get your money.
Old Jan 13, 2005 | 10:30 PM
mffi115's Avatar
mffi115
Default I just got mine - haven't installed it yet.
I'll fall for a $59.95 gimmick but not a $300.00 one, I guess.
Old Jan 13, 2005 | 10:51 PM
Aqua94vette's Avatar
Aqua94vette
when I went from stock and put on the Granetelli Mass Air and BBK throttle body and a K&N filter with cut lid I went from a 13.75 to a 13.28 in the 1/4 mile and made a hell of a difference on the *** dyno.
Old Jan 13, 2005 | 11:08 PM
kwik_ta's Avatar
kwik_ta
A performance MAF and an Airfoil gave me 40hp to the rear wheels!!!
Old Jan 14, 2005 | 03:07 AM
smacko's Avatar
smacko
Roger
Get one ONLY IF your existing MAF is dead. There are many posts about screen removal etc; Personally I only removed my rear screen as too costly gaining a few HP IF some bit of crud DOES manage to get past filter housing and hits the tiny wire...JUST my oppinion
Old Jan 14, 2005 | 03:58 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I bought a gran MAF and now the car stinks all the time it gave me 75 hp gain .
I just bought one because my old one was cracked thanks to chevy replacing the water pump.
Old Jan 14, 2005 | 04:11 AM
smacko's Avatar
smacko
75Hp ey? Order me 500 units!
Old Jan 14, 2005 | 04:35 AM
REDC4CORVETTE
They will arrive by tunnel in a minute ?or was that the bridge.I 'll just take a few links out of the island chain and be their soon with all 500!!
Old Jan 14, 2005 | 04:47 AM
smacko's Avatar
smacko
Good on you mate!
Had I would've known in late December, I could have asked Santa to drop them off to me here in Australia...Damn; now I have to deal with freight costs!
Old Jan 14, 2005 | 08:20 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
We have used the Stock MAF (de-screened and gutted - no air fins) to low 10 sec 1/4 mile times on our 434s. You will be wasting your money on a larger one, unless your making more than 650+ HP naturally aspirated.
I have run both SD and MAF and they are transparent - the MAF actually 60's better with the tube and MAF in place than the SD does in repeated tests.
Don't bother- get something than will matter.
Old Jan 14, 2005 | 09:29 AM
LT4BUD's Avatar
LT4BUD
Can't arque with that kind of success.......
I am looking at the larger body MAF....82mm....since the cross sectional area of a single 82mm opening matches almost exactly the cross sectional area of twin 58mm throttle body...and I did already go with the 58mm throttle body
If you upgrade to 58mm throttle body without upgrading the MAF it seems like you have created a mismatched system of sorts?????
I am going to spend the $59 it hopes that it might help....still haven't seen it but it is on order..
Update: I just got it......smallest diameter is 80mm plus I am not sure about the "air foils" in the center.....
Old Jan 14, 2005 | 12:55 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default performance MAF
Will this airfoil work for an 1986?
To Performance MAF?
Old Jan 15, 2005 | 06:37 PM
BMarsh93's Avatar
BMarsh93
LT4BUD -
I would be most interested in what you think about your ported MAF. I might do the same.
Old Jan 15, 2005 | 09:45 PM
LT4BUD's Avatar
LT4BUD
Originally Posted by BMarsh93
LT4BUD -
It looks pretty good.....not sure when I'll get a chance to install it......might be a week or so......
Another forum member did this and said it was pretty easy to install
Old Jan 15, 2005 | 09:50 PM
ClarenceT's Avatar
ClarenceT
It will install, yes - but it won't add any power. It was a joke, they were comparing "performance MAFs" to the airfoil (which is notorious BS, like the turbonator, etc)
point is, all those "free" or super easy mods don't really do anything. Want more power, sorry bud, but you'll have to change something that actually matters.
Air delivery is always a bottleneck (fuel is easy, spark is too) as well as it's removal. Cams, heads, headers, intake manifolds - those are things that will actually create a need for more airflow. There are people running 10s on this board with stock MAFs, so obviously that isn't a bottleneck.
As for descreening your maf, read this:
http://www.gmtips.com/3rd-degree/dox...maf-screen.htm
....and stop worrying about it.
Seriously people, quad tip spark plugs, jumbo-sized MAFs, what's next? How about header-wrap on your spark plug wires? less heat = less resistance = faster spark, right? Quick, let me make a kit. $59.99 and typically gains 12 rwhp*. Order yours today!
*Actual gains may vary.. a lot.
