Magnaflow cat back install
Old Jan 14, 2005 | 12:17 AM
bops90's Avatar
bops90
Default Magnaflow cat back install
Last year I installed ford sov 24pd injectors.It runs a little rich.Now that Im going to install the cat back magnaflows will the free flow exhuast have any effect on the burning of fuel? Thanks Mark
Old Jan 14, 2005 | 10:03 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I think you'd need long tube headers to actually affect the fuel flow.....
Thats the only exhaust stuff I've ever heard effecting fuel flow / mixture.
Old Jan 14, 2005 | 10:35 AM
bops90's Avatar
bops90
Thanks Vic,kind of what I thought needed to hear from someone else.Going to change out ujoints while im at it.And anything else i see in need of repair. Mark
Old Jan 14, 2005 | 10:39 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Good luck bud. Let us know how it goes!
Old Jan 14, 2005 | 11:17 AM
bops90's Avatar
bops90
Will do !!!!
Old Jan 14, 2005 | 02:36 PM
TA's Avatar
TA
I can't help you with the exhaust question, but I thought I'd give you my experience with the 24 lb Ford injectors. I put them on my 91 a couple years back and since both our cars are speed density they probably acted similarly in the cars. My car also ran very rich after the injectors and no amount of fiddling with the fuel pressure (holley afpr) would improve the situation. I ended up having a custom prom burned which corrected the problem. I got dyno runs with a/f readings somewhere around here. I suspect your in the same boat as me. It seems that a lot of the MAF guys can get away with these injectors without tuning, but the SD didn't seem to like these changes.
Old Jan 14, 2005 | 03:29 PM
bops90's Avatar
bops90
Thanks TA,Where did you get the prom burned and how much in cost.Thanks Mark
Old Jan 14, 2005 | 04:25 PM
TA's Avatar
TA
I used a shop in my neighborhood that has a dyno, JD's Performance (Huntingdon Valley, PA). I think I paid about $225 or so for the custom chip which included dyno runs with a/f readings.
To Magnaflow cat back install
