It looks like my diff. was changed but I do not know the ratio 80 mph is about 2000 rpm. can anyone give me an idea.
I don't really know - I'm guessing that you need to know the size of your tires and the tranny and gear you were in. But just for fun - to play with numbers:
80 MPH calculates out to 7040 ft / min
If your tires are standard - I think they are 28"tall - so their circumfrence would be about 88 inches or 7. 3 feet per revolution
So the axles would be spinning at 960 times per minute (960 RPM)
You say the engine is spinning at 2000 RPM - so the speed would be reduced at a ratio of .48 - or the engine is turning 2.08 times for every wheel turn.
I have no idea if this is the correct approach - I'm thinking I would need the tranny gear ratio to go any further - because using this approach I still have 2 unknowns - the diff gear and the trans gear
I did some figuring for another member only a couple of days ago. With a 26" (very close to our stock tires) tires, his car should have gone 81 mph @ 2000 rpms with his 2.73 gears.
