how do I remove the battery?
Old Jan 16, 2005 | 02:29 AM
redbullapril23's Avatar
redbullapril23
Default how do I remove the battery?
do I take the innder fenger well out?
or the side panel?
if so how do I take it out...
when I put it back in do i need to align it or just bolt it in?
thanks your friend
Sean
Old Jan 16, 2005 | 03:21 AM
Mo_Bandy's Avatar
Mo_Bandy
Hi Rebull,
There are about 4 Torx type scres lining the fender well and 2 10 mm bolts on on the top near the door jam.
f youlook in the seam near the rocker panel there is anoter 10 mm bolt there as well. You can slide an open end wrench in and loosen it up, you shouldn't have o pull it all the ay out but if you loosen it it should allow you enough room to pull the battery out.
Mo
Old Jan 16, 2005 | 03:49 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Before you start, turn the steering wheel about a half turn to the left. Makes it easier to remove the torx screws....
Old Jan 16, 2005 | 05:28 AM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
you just grab a big hammer and one good swing
now you have very good access to your battery and the underhood fuses just kidding i agree with them
Old Jan 16, 2005 | 09:03 AM
Sam Lam's Avatar
Sam Lam
Redbull: This project really looks much worse BEFORE you do it. It is really not that bad! Just a note that as you reassemble the side panel, take the time to adjust it so that the spacing between it and the door is the same as the spacing between the hood edge and the door. This will prevent the door from rubbing the panel when you open the door.
SAM
Old Jan 16, 2005 | 11:41 AM
redbullapril23
awesome guys! thanks alot!
Ill go remove it today and then Go get a new battery from NTB
thanks alot your friend
Sean
Old Jan 16, 2005 | 01:59 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
When you go to the battery cable use a 5/16 NOT, I repete NOT 8mm.
Old Jan 16, 2005 | 03:31 PM
96dblblack's Avatar
96dblblack
SAM
The previous owner did not do this. It takes about 2 minutes to line it up right. This is time well spent. Easy project.
To how do I remove the battery?
