Can anyone post the factory suspension geometry settings(camber,castor and Toe) and offer advice on any improvements over Factory settings.
My car is a 90 ZR1 i use for road and tha odd track day.
Thanx.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I don't have the stock settings handy but here's the advanced street specs commonly used. These will improve handling noticeably without causing any undue tire wear.
Front: toe 0 / camber 1/4 neg. / caster 5-7 pos.
Rear: toe 1/8" in / camber 1/2 neg.
Just wondering where these numbers came from. I had my alignment set at "advanced street" settings I found in a Corvette Fever magazine, and have since lost the magazine. I'm wondering if these might be the same. THANKS!
