The heat blown is hotter than the ambient temp, but not nearly as hot as it should be. Since I have some heat I am guessing the core is not plugged but possibly partially restricted. NE1 have this prob and if so did you try a coolant flush?
96 ...radiator has ~20k.
Do you have the electronic HVAC controls, and if so, is this with the temp set to the highest? (I think it's 90 but I forget)
Did the problem just start all of a sudden or has it always been like this?
Mine only blows hot if I have it on 90 and only blows cold if I have it on 60. In between I get lukewarm. It's been that way since I've owned it. I suspect maybe the temp sensor is messed up, but I haven't gotten around to investigating. The airflow from those tiny vents is so small that I pretty much need to run it on max anyway.
If you suspect a heater core problem, I wouldn't do a flush until you have time to change the core because the flush may cause a leak.
