lt4 conversion kit?
Old Jan 16, 2005 | 11:53 PM
96dblblack's Avatar
96dblblack
Default lt4 conversion kit?
I posted this in the general discusion part and think that it might have belonged here. I am considering installing the the kit and am wondering if any of you have and what kind of results you got from the install? Any feed back would be great.
Old Jan 16, 2005 | 11:55 PM
VenkmanP's Avatar
VenkmanP
You might want to look back through recent posts. This is about as FAQ as it gets.
Old Jan 17, 2005 | 10:00 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
So, you have an LT-1/auto in your '96 and want more power?
Save your money.
I don't think the LT-4 is that much faster than the LT-1, at least not enough to justify the $$ for the kit (which doesn't include the bottom-end components to support the slight extra power/rpm)
Just my opinion...
Larry
code5coupe
Old Jan 17, 2005 | 10:02 AM
comp's Avatar
comp
interested
Old Jan 17, 2005 | 12:57 PM
crheinish's Avatar
crheinish
It is a good kit that will make 430 HP @ the crank. If your car is an auto add a 2800 converter, LT headers, 3.73 gears. For a man trans LT headers and 4.10 gears should do the trick. Don't forget to get it tuned.
Old Jan 17, 2005 | 01:20 PM
redbullapril23's Avatar
redbullapril23
its a great kit! But it depends what you want!
do you jsut want say 100 more hp or do you want a real kick in the butt and want like 200-250 more?? obviously more kick = more $
if you dont ahve the $ go with the kit its a sure fire way to safely gain about 100 hp over stock lt1 with a tune. make sure you get LTS!
if you want more power go with aftermarket heads and a big cam.
youll get more power but also burn more gas, idle choppier, and spend more. the choice is yours.
good luck your friend
Sean
please email me for all yur ceramic coating, powder coating and deep cryo processing needs!
headers =$188 ceramic coated! 3 yr warranty and limetime rust warranty!
Old Jan 17, 2005 | 03:01 PM
rocco16's Avatar
rocco16
Sorry, but LT-4's do not make even 50hp more than an LT-1.
Larry
code5coupe
Old Jan 17, 2005 | 04:28 PM
VenkmanP's Avatar
VenkmanP
Irrelevant.
Old Jan 17, 2005 | 05:08 PM
mn_vette's Avatar
mn_vette
Larry
code5coupe
the LT4's were under rated, and the conversion kit comes with the hot cam kit as well. That helps quiet a bit too.
Old Jan 17, 2005 | 10:25 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Larry
code5coupe
This set up with a HOTcam, 52mmTB, long tube headers, and custom program, was tested at the crank @ 425-430hp
Old Jan 17, 2005 | 10:31 PM
redbullapril23
thats over 100 hp at the crank!
meaning a huge kcik in the butt!
the lt4s were uncer rated and are faster than stock early c5s!
and with the hot cam its another big boost so yes they do make that much power and more!
To lt4 conversion kit?
