Understanding port swirl
Old Jan 17, 2005 | 12:58 PM
Carl90's Avatar
Carl90
Default Understanding port swirl
The head manufactures advertise port flow numbers and port size (affects velocity). I never see any specifications regarding swirl performance.
My understanding is that a good port design for swirl will show up as improved low and mid lift port flow numbers. For comparing aftermarket heads...is there more info required to compare performance potential between heads?
Old Jan 17, 2005 | 01:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
In David Vizard's books on building SBCs he mentions that stock #113 Vette heads ('88-'91) already have good swirl and that porting should be done so as to not diminish it or, even better, to enhance it.
Further, swirl seems to depend on factors like port bias, chamber design and valve lift. I think that swirl is both complex and difficult to measure, so is not usually even mentioned as a head spec parameter. Yet it is very important in extracting the most from a set of heads.
Old Jan 17, 2005 | 01:49 PM
tempest's Avatar
tempest
port swirl (and tumble) are difficult to describe with a number, or even several numbers since much of the effectiveness of the swirl has just as much to do with the geometry as well as the speed (linear & rotational) of the mixture.
what makes swirl and tumble even more interesting is how combustion chamber and piston design affect how swirl and tumble changes as the piston compresses the mixture, kinda like a figure skater pulling her arms in to spin faster.
i'm guessing here, but swirl and tumble are only part of the picture. i would also thing spark plug placement relative to the mixture flow would also significantly affect how effective the swirl/tumble performance is.
Old Jan 17, 2005 | 02:57 PM
CFI-EFI's Avatar
CFI-EFI
Not necessarily. While it is hard to measure or post "swirl" numbers, the effect shows up in the flow numbers. As I try to stress concerning horsepower and torque curves, look at ALL the info available, not just the maximum values. Good ports will show superior flow at low valve lifts. Look and compare the flow numbers at .200" and .300" valve openings. Even if the max numbers don't peak the highest, you can select a better head, particularly at street usable rpms, this way.
Port swirl and combustion chamber swirl, while similar in nature have two different advantages. Swirl (turbulence) in the combustion chamber helps spread the flame front around, resulting an a quicker, (fast burn) more efficient, combustion process. One way to promote swirl in the combustion chamber is to build in the tightest quench area you dare.
RACE ON!!!
To Understanding port swirl
