Need Advice - Pistons, Computer, ignition?
Old Jan 18, 2005 | 12:57 AM
Draven's Avatar
Draven
St. Jude Donor '14
Default Need Advice - Pistons, Computer, ignition?
Around March 1st, my car goes into the shop for my build:
Intake:
Superram plenum, runners, edlebrock base all port matched, 52mm TB
Set of 113s have been ported/polished to 2" intake, 1.6" exhaust.
30lb Delphi injectors (I know, bigger then they have to).
EM 1 5/8ths LT headers, Y pipe, hooked up to my current Flowmaster exhaust (gonna be loud) ; )
SR 219 CAM, Comp Cam 1.6 RRs, new roller lifters...
Now, that said... I was thinking about bolting those parts up to my stock 350. The builder ( a member on the forum ) has made some suggestions, due to the lack of emissions here and eliminating the EGR, as well as the air pump eliminator pulley, etc.
NOW.. I was wondering what else would be recommended for my build. I was thinking of going with pistons (but didn't know if I should leave that in case I wanted to work the bottom end later)...
I was thinking of a computer, but also realize that the member doing my build is taking care of tuning at the same time.. Wasn't sure if I would gain anything moving away from the stock to an aftermarket..
Now, probably the most important... How about ignition systems? Am I taking a risk (or losing anything) with sticking with the stock system?
Thanks for your time, guys,
-Joe
Old Jan 18, 2005 | 01:18 AM
bogus's Avatar
bogus
How many miles are on the engine? If it's over 100k, I would get the bottom end looked at.
Considering you are making a huge bump in power, the rings and bearings should be looked at.
It really isn't going to cost much more than that.
Old Jan 18, 2005 | 01:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
If you have it stripped that fardown, might as well do it. Would be a good opportunity to replace other items such as oil and coolant hoses, etc,-Small stuff that is hard to access once its all together. Plus you wont be wincing if your'e getting on it with an old bottom end.
Old Jan 18, 2005 | 01:41 AM
bogus's Avatar
bogus
oh, ignition... I really don't know enough about GM Ignitions to know if after market is really any better.
Old Jan 18, 2005 | 01:55 AM
JCAIRE2's Avatar
JCAIRE2
GM HEI is good up to about 6K rpm, so unless you plan on spinning higher than that, I wouldn't look to ignition right now. Unless you're going to N2O.
Old Jan 18, 2005 | 02:26 AM
85 500 horse's Avatar
85 500 horse
Weisco forged pistons are a very good choice and for what you are doing, I'd do it. I'd also go with the Weisco moly rings.
Old Jan 18, 2005 | 07:36 AM
Draven's Avatar
Draven
St. Jude Donor '14
40k miles...
Any complete kits you / anyone would help. : )
-Joe
I'll run that by the builder. Tell ya where we end up. So far, I'm getting a no go on another computer (which I figured), ignition is good to 6k (which was what I was comfortable revving to anyway.. Don't want to push it), and a set of pistons would be something to think about.
-Joe
Old Jan 25, 2005 | 05:03 PM
Draven's Avatar
Draven
St. Jude Donor '14
Alright, from what I understand, stock compression is right around 9.5:1. I'd like to bump it up to around 10.5:1 (I run high octane anyway, and this should be safe.)
Any recommend some pistons with some p/ns?
Thanks,
Joe
To Need Advice - Pistons, Computer, ignition?
