Why the LT4 ??
Old Jan 18, 2005 | 02:57 PM
Bobalooo's Avatar
Bobalooo
Default Why the LT4 ??
I was thinking about this the other night. Why did GM go through the expense of R&D and tooling to produce the LT4 for only 1 year?
I certainly see the advantages of the motor and am guessing they may have offered it in another car, but again why in the first place and why so short lived?
Old Jan 18, 2005 | 03:36 PM
k99ja04's Avatar
k99ja04
They were probably ready to go with the LS1 engine by then. I know development started for the next generation small block in 1991. By 1993 decided they couldn't just improve on the LTx small blocks and that the Flint assembly plant was too expensive to retool, so they had to come up with a whole new engine thus the LSx series (and built a new plant). What improvements they already had on the LT1 up to that point went into the LT4. I'd also like to believe they wanted to do something special for the last year of the C4's. Wasn't something similar done for the C3? Too bad they didn't have a Grand Sport C5.
Jared
Old Jan 18, 2005 | 03:38 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Jared
Old Jan 18, 2005 | 03:40 PM
jrp's Avatar
jrp
Originally Posted by Bobalooo
...the expense of R&D and tooling...
I'm guessing that there wasn't need for a whole lot of either, and with the LT5 gone, something needed to fill the "more HP" hole. Other than that, it makes me a happy camper 7 years later .
Old Jan 18, 2005 | 03:49 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Jared
That's pretty much it. The LT4 was basically the iron counterpart to the LS1.
Old Jan 18, 2005 | 04:13 PM
JCD's Avatar
JCD
The last C3 had the crossfire, right? They carried that over to the '84 then upgraded again in '85?
Quick, someone do some research....
Old Jan 18, 2005 | 04:20 PM
vader86's Avatar
vader86
82 was a crossfire, yes.
GM had to tool up the LT1 in its last year of production because most of the information about the C5 was already out, and they wanted to give people a reason to buy the 96s, so they bumped up the power. GM usually does this when they know people will just wait to buy the newer, improved model.
bogus's Avatar
bogus
yes, so what's the question?
The C5 was supposed to have the LT5 in it. But GM nixed idea as expensive.
The Vortec truck engine is directly related to the LSx series of motors. They share structure and internal design, however, their tasks are totally different. One is a truck motor, one is a sports car motor.
The LT4 was done as a last hurrah for the original SBC. It was used in the 1996 Vette and about 100 1997 Camaro Z28 SS models.
There was no other reason than to say good by to the original SBC design.
I don't view the Vortec and LSx family of engines as being small blocks, tho... they are different animals... no parts interchange...
BTW, the big 8.1 litre truck Vortec? That's actually a Mark IV 454 bored out.
Old Jan 18, 2005 | 05:40 PM
MikeC4's Avatar
MikeC4
did all '96's come with the LT-4, or was this an option, with the LT-1 as base?
what are the published HP and Torque specs for the LT-4?
inquiring blogger wants to know!
Old Jan 18, 2005 | 05:53 PM
comp's Avatar
comp
good question
Old Jan 18, 2005 | 06:00 PM
96CollectorSport's Avatar
96CollectorSport
From: If you don't weigh in you don't wrestle Road America
The LT-4 was an option and the published hp was 330hp and torque was at 350 ft/lb.
The Corvette has always done something to say goodbye to a generation. The 67 was definatley the best of the mid-years (mostly interior changes) In 1982 they did the cross-fire (not sure if that is exactly a bonus or not? Sorry any x-fire lovers if there are any . Then in 1996 they did the LT-4, I also read that Chevy wanted to continue to have two engine options and since they ran out of LT-5's they made the LT-4's. But the biggest reason was for people like us to have something to talk about.
Old Jan 18, 2005 | 06:30 PM
LT4BUD's Avatar
LT4BUD
Last hurrah for the C4.......yes
Something special..Grand Sport to get people to buy........yes
But I think significantly the LT4 was a result of GM's struggle to determine if it was going to continue with tradition or change direction to LT5 type overhead cam engines.........obviously it has turned out that the "traditional" small block tradition has continued with Corvette......in the early 90's the committment to the traditional small block was being seriously challenged by small efficient dual overhead cam engines...lot of speculation a C5 would be mid-engine or ????
Legend now is the GM engineers did too good of a job with the LT4........possibly the hot cam was planned for production, 52mm throttle body, significance of mismatch ofthe head/intake ports......all suggest the LT4 was tamed by the marketing dept at the last minute...my bet is it was making more hp than the LT5,probably more than 400, with lower cost/better mpg etc...
Still an interesting question...why didn't they just wait for the C5.......and go with the LS1........
Old Jan 18, 2005 | 06:37 PM
jlallande's Avatar
jlallande
6th Gear
All the 1996 6 speeds were LT4's (about 1/3 of the total produced). The automatics were LT1's.
Old Jan 18, 2005 | 08:48 PM
vader86's Avatar
vader86
All manuals are LT4. All automatics are LT1.
330 and 350, but the LT4 is underrated because of the LS1 to come out in the 97. LS1 puts out 345 in its early years, but the LT4 actually puts out 350 HP at the crank, GM purposely underrated it.
Old Jan 18, 2005 | 10:34 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Old Jan 18, 2005 | 10:57 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Old Jan 18, 2005 | 11:49 PM
87Z-ya's Avatar
87Z-ya
I love traditional small blocks, but I am tired of hearing the lt4 was underrated because of the ls1. Thats a bunch of crap. I am sure the lt4 is underrated because of averages, but thats another story. The traditional small block cant whipe the lsx's ***. It is a far superior design in many ways. The cylinder heads are 15 deg compared to 23, and are more efficient through higher velocity just to name one. The gen 4 ls7 heads are 12 deg and it uses titanium connecting rods! That is going to be an insane factory engine. I love my c4 but if I had the coin I would jump on a c6 z06 like no tomorrow.
To Why the LT4 ??
Old Jan 18, 2005 | 11:57 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Im, sure the marketing dept cared. The LT5 program had been dead since 93. GM's main concern was the LS1 being a higher horse variant than the model it replaced. You don't sell a 300 horse engine one year and come out with a all new one producing 275 the following year.
Old Jan 19, 2005 | 12:04 AM
rockindaves96's Avatar
rockindaves96
check out www.grandsportregistry.com they have the specs and diffrences bettween the lt1 and lt4 we got a good deal for the 1500 option when you see what it all includes. steel crank.sodium filled valves.forged rods..ect check it out for yourself its an interesting read.
Old Jan 19, 2005 | 02:13 AM
bogus's Avatar
bogus
Sounds like we have some issues here...
If you ever read the book, "Corvette from the Inside" by Dave McClellen, it is rather obvious that the LT4 was underrated.
GM had a hell of a problem (so did all automakers) telling the consumer that 340hp is really the same as 450hp, when they went from SAE gross to net ratings.
An all new Vette was being released, and it had to be better, in all facets, than the prior version. That meant, it had to have more power than the base model it replaced. The engine was new, the drivetrain, the chassis, everything.
If variances were the reason, just about every one here that has been tested on a chassis dyno tell the tale... They are all testing in the 300hp range, or more, and with a 15% error rate, that works out to 350hp.
