Wheel nut threads Gone need Help
Old Jan 18, 2005 | 11:27 PM
My87's Avatar
My87
Default Wheel nut threads Gone need Help
Doing the entire brake system on my car and 15 minutes into the job and I ran into problems
When I tried to take the take the back tire off the car it seems that the previous owner not only over tighten the bolts but he completely stripped two of them.
I have tried everything to take them off and I can't.
What is the next step?
1. Take it to a tire place? And do they charge a lot for taking these off?
2. Getting a drill and completely drilling out the bolt and screw?
I am loosing my patience as I tried a number of things and I think I just made it worse.
Old Jan 19, 2005 | 12:16 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I would grind the nuts till you can split them without too much pounding; then remove the wheel and press out the two studs.
Use a large socket over the rear of each stud with a nut on the threaded end and a large C-clamp to press out the studs. A little PB Blaster and a copla raps with a hammer might help to get them started but don't beat too much on them.
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Buy or borrow a good nut splitter tool. You'll also in all likelyhood have to replace those studs too, once you get it apart.
Old Jan 19, 2005 | 11:22 PM
My87's Avatar
My87
I am sorry if I sound ignorant but is there a nut splitter tool out there? Do you think I might be able to buy it at the local Auto Parts store?
Old Jan 19, 2005 | 11:34 PM
SPEED750's Avatar
SPEED750
You might want to save yourself the headache. Call around to some local tire shops and see if they can get your nuts off. (sorry coudn't resist) I think most shops have a tool for this, like when people lose the key for anti-theft lugnuts. If your nuts are recessed in the rim (like most) getting a nutcracker on it might be tricky.
Old Jan 20, 2005 | 01:23 AM
Jloshotz's Avatar
Jloshotz
Not to mention damaging to the wheel. If you have Pep Boys in your area and are set on trying this yourself, i think i remember them having an odd type of tool thingy for this. I had this trouble with an old Trans Am i had, and let me tell you, i ended up using eveything from a dremel to a sledgehammer and the wheel was pretty fugly once i got it off.
Old Jan 20, 2005 | 02:07 AM
froggy47's Avatar
froggy47
PEP Boys sells a tool for getting off the locking nuts when you lose the key. Might work
To Wheel nut threads Gone need Help
