dyno graphs
Old Jan 20, 2005 | 05:19 PM
1996man's Avatar
1996man
Default dyno graphs
post them if you got them! tell us what you have done. even more so if the dyno was done after just a few parts to help narrow down what parts add what power. this should benefit a lot of ppl and maybe even answer some future questions
Old Jan 20, 2005 | 08:50 PM
1996man's Avatar
1996man
no one?
Old Jan 20, 2005 | 09:01 PM
chriswtx's Avatar
chriswtx
Here's one for you...
http://forums.corvetteforum.com/showthread.php?t=964693
Old Jan 20, 2005 | 09:35 PM
FD2BLK's Avatar
FD2BLK
PIcked up 31 HP from the tune motor had 500 miles but had a miss (The blank part a little over 4K) because of a bad opti. Opti has been replace and I corected a huge exhaust leak so I am hoping for 420+ next time I get some tune work done
383 Stroker, Forged Scat rotating assy & SRP pistons, AFR 195 More performance comp Ported heads,Comp 306 Cam, Comp Pro Mag 1.6 R/R, LT4 port matched and 58mm bored intake, Holley 58mm TB, Stainless LT headers, Magna Flow cat back (No cats), DELTEC ignition, Stainless Long Tubes, FMS 36# injectors Meziere W/P, BeCool Radiator
http://www.cardomain.com/memberpage/750813
Old Jan 21, 2005 | 03:38 AM
Perfusion's Avatar
Perfusion
These runs were done with the mods in my sig...basically K&N and full exhuast.
Notice the 2 "blips" in the upper RPM range - that was the first two runs. It got smaller with each run, and by the third it was basically gone. The tech thought is was knock retard, but I dunno...
Old Jan 21, 2005 | 10:38 AM
FELNGR8's Avatar
FELNGR8
Default Your basic LT1 top end kit here
The first run in 2003 is with the heads/cam work but still running the stock cast iron manifolds and old exhaust.
The second run is with the heads/cam and now TPIS headers and full 3 inch exhaust behind it letting it breath. Notice how much the torque is improved with max exhaust breathing. A heads/cam can't do its thing if the exhaust is choking.
The run not yet done is after getting my TB bored to 52mm to open the intake some. But I'm scheduled for Monday and this weekend it's going to snow. So probably not going to do it.
Last edited by Mr Mojo; Jan 22, 2005 at 12:30 PM. Reason: changed pics to clickable thumbnails
Old Jan 21, 2005 | 11:18 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Don't know how to post a sheet of paper...
Larry
code5coupe
Old Jan 21, 2005 | 11:19 AM
racerns's Avatar
racerns
Originally Posted by chriswtx
That is a nice looking curve, but you do realize that your graph is using the STD correction which in most cases will yeild higher hp numbers. I noticed almost a 20hp difference between the SAE correction and STD correction numbers. SAE is considered the more universal correction factor. If you have your file and the dynojet viewer then you can adjust to which correction factor you want.
Old Jan 21, 2005 | 11:32 AM
Nathan Plemons's Avatar
Nathan Plemons
http://www.wku.edu/~nathan.plemons/h..._corvette.html
Old Jan 21, 2005 | 01:11 PM
FD2BLK's Avatar
FD2BLK
Larry
code5coupe
I scaned mine then sent it to my web host (The forum will host the pic for you)
Old Jan 21, 2005 | 03:26 PM
Perfusion's Avatar
Perfusion
Larry
code5coupe
Got a digicam? Lay it flat on your kitchen table, and take a picture!
Old Jan 21, 2005 | 03:46 PM
JCD's Avatar
JCD
This is almost perfectly stock:
Old Jan 21, 2005 | 09:28 PM
LT4BUD's Avatar
LT4BUD
[QUOTE=FELNGR8]The first run in 2003 is with the heads/cam work but still running the stock cast iron manifolds and old exhaust.
QUOTE]
Pretty impressive gains from exhaust work....45.7 ft-lbs & 36.4 hp!!!!!
You must have raised the rev limiter from 5800 to 6300
Old Jan 21, 2005 | 09:47 PM
FELNGR8's Avatar
FELNGR8
[QUOTE=LT4BUD]
Raised the rev limiter to 6400.
I'm hoping the 52mm helps it above 5800 rpm, so it doesn't drop off so drastically at 6200.
Old Jan 22, 2005 | 12:01 PM
TwoFast4Lv's Avatar
TwoFast4Lv
Stock bottom end LT1
Lloyde Elliot heads
GM #847 cam
58mm(showed over 20RWHP gain)
Hooker Long tubes
Usual bolt ons
Daily driven
http://groups.msn.com/WashingtonFBod...to&PhotoID=439
Old Jan 22, 2005 | 12:29 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Stock LT1 six speed(at the time about 110,000 miles)
Only mod-Corsa exhaust.
Old Jan 22, 2005 | 12:31 PM
Mr Mojo's Avatar
Mr Mojo
Larry
code5coupe
Scan it, then you can post it.
To dyno graphs
