Turbo Cam
Old Jan 21, 2005 | 10:37 AM
mn_vette's Avatar
mn_vette
Default Turbo Cam
I've been looking around and calling people and reading threads and I'm still not sure what I should be doing for a cam. I called a few cam companies and here's what they advised me. Pretty wide range there.
1.) 230/227 .544/.560 lift 114 LSA
2.) 232/232 .539/.539 lift 114 LSA
3.) 224/218 .536/.528 lift 114 LSA
4.) 221/217 .540/.539 lift 115 LSA
Here's what I've got:
This car is a daily driver.
LT1 393ci 8.5-9.2:1 CR(setting it next week)
Ported Stock heads - numbers say keep lift under .550
I'm going to keep it under 6500 rpm's
I'm using stock manifolds to dual 2.5" to a single 3" to the p-trim T76 to a 3.5 out the back.
Auto Car 2500 stall, 3.45 rear end.
Any kind of help would be appreciated, especially what kind of turbo cam you're running and what numbers you're getting. Thanks
Old Jan 21, 2005 | 10:45 AM
tjwong's Avatar
tjwong
For what its worth in my car I am running a 224/236 on a 112. It offers great street manners for a daily driver but still has a very noticable lump to the cam. But my car is supercharged rather than a turbo. In my opinion for the mods that you have and the intent of the car, I would choose one of the bottom two cams from your list. Or something slightly larger than the last two but staying below 230 intake duration. Going more than that and you will have more overlap to bleed off boost which you don't want in your case.
Old Jan 21, 2005 | 11:50 AM
mn_vette's Avatar
mn_vette
how about something like this?
224/221 duration, .536"/.542", 114lsa
still gives me -5.5* of overlap and the lift is about where I want it. I'm worried that my restictive headers and turbine housing are going to need a little extra duration to push the air out.
Old Jan 21, 2005 | 11:54 AM
spindoctor's Avatar
spindoctor
Your setup really needs a custom grind. Call me and I will get you what you need.
Old Jan 21, 2005 | 03:47 PM
mn_vette's Avatar
mn_vette
GGGGGRRRRRRRRRR...................just got word back today that when they magnafluxed my crank that it was cracked on all 4 rod journals. I guess I'm going to be getting a new crank, maybe I'll destroke it down to a 355ci and drop the compression alot with my -24cc pistons.
Old Jan 21, 2005 | 10:23 PM
ANTI VENOM's Avatar
ANTI VENOM
I can't give you numbers, but I chose a Comp Cams turbo grind...224/224 .605/.605 w/1.6rr on a 114lsa. It is going in my 383 w/ 9:1 comp. As you know it is still "in progress". Maybe this summer is the one! Good luck with your project.
Old Jan 22, 2005 | 12:40 AM
Bruce's Avatar
Bruce
I talked to Jim over the Fbody. His turbo 355LT1 made 847rwhp, Per him the 224 cam has some low rpm surge and he did not like and swaped out to a 218/218 turbo cam. But when use with a 383ci motor maybe the 224 will better than a 355. Now he wants to try the 221/221 turbo cam.
Bruce
Old Jan 22, 2005 | 03:14 AM
tjwong's Avatar
tjwong
Bummer what kind of a crank was it?
Old Jan 22, 2005 | 08:53 AM
ANTI VENOM's Avatar
ANTI VENOM
Thanks for the info Bruce. MN "was" going with a 393ci, and should be able to get away with a little more cam...
Old Jan 22, 2005 | 11:36 AM
mn_vette's Avatar
mn_vette
It was an eagle 4340 forged crank 3.75" that was offset ground to a 3.85" stroke. That's how I got my 393ci. I think it was from my random expariments with the turbo and no intercooler last year. I know I was getting detonation from the blown head gaskets, and I'm sure when the nitrous blew the engine that didn't help either.
This time it's going to be dyno tuned and then set back a few to keep it safe. And then not touched again.
As far as the crank stuff goes, I really didn't budget anything for it so I'm SOL on that part, but I think I'm going to get a smaller crank and a new set of pistons to get a propper 9.0:1 compression. I'm just hoping the price won't kill me, but that's what credit cards are for, right?
Old Jan 22, 2005 | 12:53 PM
tjwong's Avatar
tjwong
Thats a real bummer....damn chinese steel. I know they are expensive but that is one of the reasons why I stay with the likes of Callies, Lunati or Crower.
Old Jan 22, 2005 | 01:33 PM
Baldturbofreak's Avatar
Baldturbofreak
I bought a scat. I hope I don't have any similar problems. Try having your next one surface nitrided or (AND) cryo'd, it might put up with a little more punishment. Big cubes are unneccary with turbo's anywho, id go back to 355. I wish I had just stayed with the stock stroke, I'd have saved alotta $$$ in machinework.
Old Jan 22, 2005 | 01:42 PM
BAM92's Avatar
BAM92
He is right. Big cubes are not necessary. Friend of mine was getting 633 fwhp out of a 3.4 liter Porsche Turbo motor. Big single turbo. Had dual injectors and dual spark plugs per cylinder though. You wanna talk expensive.
Old Jan 22, 2005 | 03:00 PM
mn_vette's Avatar
mn_vette
That is true, however, I've got to get new pistons and crank, and the machine work is already done on my old block. And in just about any given situation at the same boost levels the bigger cubes win.
So I'll take the extra 33ci(if I go 383) for the same price. Having the extra torque before the boost comes in will be nice on the launch.
I'll have to talk to my parts guy, maybe he can get me something other than eagle this time. I hope it won't cost too much more.
Old Jan 22, 2005 | 03:16 PM
Baldturbofreak
I got my scat crank for $500 from cnc-performance
Old Jan 22, 2005 | 04:04 PM
mn_vette's Avatar
mn_vette
is that a 9000 series or a forged???
from www.cnc-motorsports.com ?
Old Jan 22, 2005 | 04:21 PM
Baldturbofreak
It's a forged 4340. I got it off ebay, so it might have been a clearence item. Call em the guy was really cool and they might work with you on the price. I paid $916 for the crank and a set of 6" eagle h beams wih the L19 bolt upgrade
To Turbo Cam
Old Jan 22, 2005 | 04:23 PM
Baldturbofreak
http://www.cnc-motorsports.com/category.asp?CtgID=7492
Old Jan 22, 2005 | 06:28 PM
ANTI VENOM's Avatar
ANTI VENOM
Yep, CNC treated me right!!!
Old Jan 22, 2005 | 07:52 PM
mn_vette's Avatar
mn_vette
BTF,
What compression are you running with a 383 and a 6" rod? What kind of pistons?? I'm looking at srp but they only have a -31cc dish for a 5.7" rod and I've got 6". I really don't want to buy a new set of rods too.
