Flow #'s for my 18* heads
91tpi-zf brings up a good point that I will need to inquire about. If the runner is longer, how much does that effect the measured size? Maybe a 245cc 18* runner has the same cross section of a 23* 220/5/7 head.
J or C, Why didn't you guys go with the AFR raised runner? Lots of air for a 215cc
OK that is a very good sign.
The 215s you mentioned have their own demons, with the use of shaft rockers, special headers (which we mentioned you will have to deal with) - for these reasons we avoided them. Seems that everything has its cost.
here are some numbers 231 cc 23% head 2.318 crosssection
here are some numbers 240 cc 23% head 2.362 crosssection
here are some numbers 256 cc 18% head 2.548 crosssection
as you can see the the 18% is pretty large
cuisinart,
M2's are Brodix Track 1 heads that are ported by company called M2. They are very good, very good. And yes you can better, but not in the price range relative to this discussion.
If you want to be a bear be a grizzley. now..........nuff said.
Is that the speed of the air at the valve?
Next to it is Port Velocity, which is of course a bunch of 0's
Where are you seeing these values at? Valve velocity I would take as "valve opening and closing speeds due to cam profile"
Do you have an engine analyzer program your looking at?
The columns are...
vlv area sq. in.
Corrected CFM
CFM/sq in
Flow area sq. in.
Flow coef.
Valve velocity
port velocity
% exh/int
Valve velocity reads...
.025 379.6
.050 375.9
.100 368.6
.200 380.3
.300 357.2
.400 313.7
.500 270.8
.600 275.1
Any chance that's feet per second of air velocity entering the chamber? There is no unit given to the measurement so I don't know what to think....
I will put them into Engine analyzer pro, using my 434 specs and see what it yields.
Those values you are lookig at are valve speeds, probably ft/sec, that is why they slow up around max lift. Most cams snap the vavles open pretty quick and then their profiles allow the valves to slow up towards the top, to allow more "dwell at max lift" this is important cause the valve is also changing directs at max lift, and if it were and abrupt change in speed and direction, it would eventually ruin the valve train.
Valves 2.15 int 1.6 exh
add to lift chart in first post
.025 17.5
.050 34.9
.700 336.9 ===>
.750 337.2 ===> I doubt I'd run a cam over.630
Chamber is 54.4cc
What else? I will try and scan the sheet...
I got the name wrong in the first post, he said they were probably by Keith Dorton Auto Specialties (ists) in Texas.
Be back in a ~hr
here they are again
int
100.......76
200.......153
300.......215
400.......261
500.......297
600.......304
700.......307
exh
100......55
200......114
300......159
400......198
500......221
600......232
700......240
Be back in a ~hr
I have not been to a bench that has this information also available,. The software is part of a series of programs, one of which I have to see how different setups perform. I am not sure how accurate the results are, cause for mine it says I am making over 600fwhp, but I don't think I am there yet - with the new cam it gained roughly 50hp across the boards- again not sure I 100% agree with it.
The information if its accurate they gave you would be very helpful in porting work or comparing different heads. As in the example corky gave with the BBC and SBC 454s, I would bet if both those heads used on the respective engines were flowed on a bench like your heads were, the BBC heads would have shown a huge decrease in port velocity
Really all they are doing to get the velocity off the top of my head is using taking the following:
ft^3/min x min/60sec x (1/(port area or valve area in ft^2) = ft/sec of airflow.
So if you had the CFM reading of a given port you could work backwards through and get the velocity that given area is flowing, but it would be a averaged area reading, unless you could take CFM reading for different areas through the port.
Again that was all just off the top of my head - real key here would be to get some "baseline" velocities off a good known performing head, like our M2s for comparison. Interesting information - I wish I was closer to you, I would be happy to go to the shop with you and see how exactly how these heads compare to other heads. I would call them and see if they can give you some other readouts of some AFR brand heads, or brodix 23* stuff. They should have some in their database for comparison purposes.
We had the flow verified on Dennis Wells' Racing flow bench here in TX.
Steve’s 15* Brodix Heads
29 Mar 01
Intake Port Height = 2.45”
Exhaust Port Width = 1.415”
Intake Port Volume = 262 ccs
Exhaust Port Volume = Not Given
Exhaust Port Height = 1.67”
Exhaust Port Width = 1.55”
Intake Port Length = 5.5”
Exhaust Port Length = 4” (Uncertain on this)
FLOW NUMBERS
CFM Measured @ 28 Inches of Water
15* BRODIX HEADS
Intake Exhaust
.100 67 57
.200 156 113
.300 227 163
.400 279 195
.500 317 221
.600 334 240
.700 340 249
Jake
