My 85 is still having a pinging/knocking problem. Here is a list of what I've tried.
-New plugs, wires, cap, and rotor
-New Fuel, and air filters
-New knock sensor
-New ESC module
-Checked the timing, and adjusted to 6* BTC...it was at 2*BTC (I think someone tried to fix it the "cheap way")
I don't have a scanner yet so I can't pull any codes, but I will get one soon. I am out of ideas though. The plug for the fan switch was sitting on top of the header, but someone had installed a new switch/sensor with a 2 wire plug so I guess the old plug wasn't needed. I thought that this might be the knock sensor plug but there was already a plug on the knock sensor (The wire on the knock sensor is blue, can anyone confirm that this is the right wire?) The fans work fine. And another thing. When I pulled the old knock sensor out, no coolant came out. What Gives!? I thought I remembered someone saying that the sensor screwed into the water jacket. Anyone have any suggestions???
well do you have a check engine light on?if so go to your local parts store and get a gm key and pull the codes yourself.If you have a auto zone in your town go there and they will pull them for free and look the code up and tell you want you need.
And the knock sensor is in a water jacket in the side of your block and if no coolant came out then either you pulled the wrong sensor or your radiator is dry.The knock sensor is about as round as a 50 cent peice and its about 1/2 inch thich with 3/8 thread that screws into the side of your block.anyway good luck.
Yeah, I'm sure that it was the knock sensor. It's the only sensor that is that low on the block, on the passanger side. It's the one right in front of the starter. Oh, and the check engine light isn't on. Only when I turn on the key. I'm sure it has a stored code from when I adjusted the timing
Did you disconnect the ECS wire (near the brake booster) before you adjusted the timing? yeah... maybe im the only one on here that ever pulled that one but that little error cost me about 300 bucks in parts when the original trouble was simply the pickup coil that was replaced (hence dicking with the timing in the first place!) and 2 months of driving around in a corvette that ran so poorly it was emberassing... you know its bad enough that YOU know its missing slightly but when you have high performance exhaust and its LOUD EVERYONE knows its missing slightly lol
Grant
-New knock sensor
-New ESC module
if that was the right sensor you pulled then you absulutely should of had coolant flow out.have you ever pulled codes on the older gms before?it is real easy,take a paper clip and bend it stright then bend it in half and stick it in the top right two plug holes on the connector where you would hook a scanner up. then turn the key forward and your check engine light should flash once slow then twice fast.it will do that twice then start giving you codes..if you haven't done this before then go to your local auto parts store and they will do it for free ( autozone).....anyway dont forget to check the coolant in your radiator.
I did unplug that plug when I set the "base" timing. And I don't know why I didn't get any coolant. Maybe the hole was corroded and plugged up. But I'm 100% sure that it was the knock sensor. I increased the timing because it's supposed to be 6* BTC. Putting it at 2*BTC just to try to make the knocking stop would just be a Band-aid. I need to fix the real problem, not just cover it up. Anyway, Could it be the PCV Valve??? The radiator is full also, I checked.
When I changed the timing it didn't make a difference. It pinged/knocked just as much at 2*BTC as it did at 6*BTC. BTW, I just ran a code scan, and all I got was #42. and the only reason I got that is because I checked the timing. If I had gotten a #43, then it might all make sense but no such luck
The whole lack of coolant thing behind the knock sensor bothers me... anything that will raise temperatures in the cylinder will help promote detonation. if you arent getting good coolant flow through the block a rise in temperature could occur from poor heat dissipation through the cooling system. I would look into that a little more closely... If the timing is not causing the problem there arent many other reasons for an engine to knock i mean its a flame in a cyl at the wrong time, if it isnt set off by the plug its being set off by somthing else and what else could it be? Carbon deposites? overheating cylinder or piston top getting hot enough to glow and cause preignition.? is it possible you have somthing clotting up the flow of coolant into the engine? That would explain why no coolant in the block yet good fluid in the Radiator... if im over the top here somone say so but thats where my mind is drifting on this one
No coolant just means the hole is cruded over. Check that the harmonic balancer hasn't slipped. Most likely culprit is the EGR valve isn't working for what ever reason, maybe the passages in the intake manifold may be plugged with carbon. If the engine has been altered, the compression may be too high. Have you tried higher octane gas? Just my ramblings.
I'm not doubting that the lack of coolant is a problem...maybe even a big problem. Infact, I'm probably going to put the car in the air again tomorrow, and pull the sensor out. Maybe poke something through the hole and see what's up. I'm sure that the cooling system needs a GOOD! flushing. I'm also going to try some SeaFoam...or similar product. Maybe it is just a matter of carbom build-up. But I am still open to any other suggestions of course
What is the testing procedure for EGR valve/system??? I have heard a few people give this suggestion. BTW, I'm running Chevron 91 octane. It's the best stuff we can get here in Arizona other than race gas.
Can you tell us when it pings/knocks?
Like when it's cold, first thing in the morning? Or when it is idling in park, or idling in D, or under WOT or part throttle? Upon start up regardless of engine temp? When it's up to op temp?
Is the sound a hard, mechanical knock like rod knock or is it in the cylinders?
Does it follow RPM?
Can ya tell approx where the pings is located in the engine bay?
The EGR valve, you can put your fingers into from underneath it and push up on the diaphram and see if it moves easily. It should also hold a vacum if applied to it. EGR valve operates only under certain times and conditions(hence all the temp/time questions above).
Have any mods or changes or parts replacements taken place recently?
Sorry for all the questions.
Here is what to look for. Make 100% sure that the balancer has not spun on the rubber gromet.
Make sure that your EGR valve is working.
This is what I think is wrong though, Your car I bet smokes on start up.. after a long time of this you get a build up of carbon on the pistons. The carbon get so hot that it will actual ignite the fuel before the spark plug does. The cure is run the car though a motorvac system.
One more thing make sure that the TPS is set right.
okay, I will do my best to answer all of those questions, and BTW, as far as I know, the car is completely stock...accept for the aftermarket fan switch set to go off at 190*. The car only does it under this scenario. If I am driving down the highway ~60-70mph, and I mash down on the throttle, the car will downshift, and I will get a ignition, not mechanical ping/knock until the car get's to ~3500rpm and higher. FYI the ping sounds like it's coming from the drivers side. It will also do if at 1/2 throttle in 4th gear right before it down shifts. It will NOT ping/knock in first, or second gear...or under 60mph. Even under hard launches, it's fine. All of this is happening at operating temps (180*-190*)...obviously I'm not revving the engine while it's cold. The outside temps here in AZ are starting to go up a little 80* high 55* lows and I noticed when it was really cold outside 35*-45* it wouldn't do it some times. I am going to the auto parts store again today to try to find some SeaFoam (or similar product) and maybe de-carbonize the engine. I will also check the EGR Valve...however, I'm not getting an EGR code at all. About the TPS, wouldn't an out of adjustment TPS set off a code???
If you have no way to check codes, how do you know you don't have an EGR code? A maladjusted TPS won't make the engine ping or knock.
What concerns me most is that you can hear the knock. It's one thing to see timing retard on a scanner caused by knock counts, but the ESC should retard the timing before you actually hear it.
Not necessarily. From his descriptions, he has pulled the "correct" knock sensor. It is not uncommon to pull a block drain plug, or knock sensor, in this case (same hole in the block) and not have water come out, due to a sludge build up. If he pokes in that hole with a screwdriver, he WILL get a bath.
So I tried some SeaFoam and it helped out quite a bit...actually ALOT!!!! Now I only get a ping/knock for a second while the transmission is downshifting...almost like the ESC is working, just not instantly. Once it settles into gear, it's fine. Still haven't checked the EGR Valve yet. That's next.
