Slightly Stumbling Idle - HELP!!!
Old Jan 24, 2005 | 07:53 PM
KayCee's Avatar
KayCee
Default Slightly Stumbling Idle - HELP!!!
Have a very annoying slight stumble while idling in gear on a stock 95 LT1 A4. I checked all of the vacuum lines. The fuel pressure is 41 lbs, which is the minimum spec. Would this be cause for poor idle?
Old Jan 24, 2005 | 08:08 PM
twkeough's Avatar
twkeough
How many miles? check for any codes? could be a few things, IAC, dirty TB, injectors, wires to name a few.
Old Jan 24, 2005 | 08:57 PM
tempest's Avatar
tempest
did you notice the fuel pressure dip when it stumbles? if so i would suspect the fuel pump.
Old Jan 24, 2005 | 09:12 PM
KayCee's Avatar
KayCee
Car has 125,000 on the clock. I replaced the IAC, cleaned the TB. Replaced the OptiSpark and the wires a couple of months ago. This started about 2 weeks ago. There is no engine service lights on. Can you throw a code without triggering the service engine lights?
Old Jan 24, 2005 | 09:43 PM
MikeC4's Avatar
MikeC4
I had the same problem with my '95, and yes, you can have codes thrown w/o SeS coming on. I had codes H22, H44, H64, which is TPS, lft O2 sensor and rht O2 sensor. Turned out to be my TPS was faulty. You can get the codes by shorting pin 4 and pin 12 with a bent paper clip on your ALDL. With engine off, short these 2 pins, then turn ignition to "on", but do not start engine. The codes will pop up where your fuel gauge is. The first code you will see is C12, which is not an error, this is only a start indicator. codes will cycle through one by one, and when it is finished a C12 will appear again, and you are finished.
your ALDL connector type would be the 16-pin type:
http://www.obd1.com/
and you can get codes for your '95 & engine type here:
http://www.troublecodes.net/GM/
good hunting!
Old Jan 25, 2005 | 08:52 PM
KayCee's Avatar
KayCee
Hey, thanks MikeC4. I have access to a code reader. I did not know you code throw codes without the system lighting up. More power to the forum.
To Slightly Stumbling Idle - HELP!!!
