Clutch slave cylinder boot
Old Jan 24, 2005 | 11:15 PM
B387's Avatar
B387
Default Clutch slave cylinder boot
While rebuilding my 87 roadster I tore the old rubber boot when taking the clutch slave cylinder off. I haven't been able to locate one in all the usual places (midAmerica, Central Corvette, Ecklers, Summit etc). Anybody have an ideas?
Old Jan 25, 2005 | 02:45 AM
LD85's Avatar
LD85
If the tear is not realy bad, you can use the gasket maker on a tube and patch it back up, it worked great for me.
Old Jan 25, 2005 | 03:56 PM
B387's Avatar
B387
I hadn't thought of that, but it might work. It was just the center piece that goes around the end of the slave cylinder that tore.
thanks
Old Jan 25, 2005 | 05:51 PM
87vetter's Avatar
87vetter
Default Possible Boot Source
You can try these places or others just like them. They are all over.
http://www.michigancorvette.com/
http://www.corvettesalvage.com/
http://www.corvettejunk.com/index.htm
To Clutch slave cylinder boot
