Dohc Hemi
Given the combustion chamber design of the LT5 is it considered a hemi?
In other words does my Vette have a DOHC HEMI?
) which I don't believe have a special name. Suzuki used to call theirs "TSCC" for "Twin Swirl Combustion Chamber".
It is considered to be a pentroof combustion chamber like other 4-valve heads. In the thread Neat started, somebody said the LT5 has a hemishperical combustion chamber, but I was so sick of that thread, I didn't bother to post a correction as there were many other errors in that particular post.
A lot of people don't know the "new" Chrysler "Hemi" really isn't a hemi. It has the intake and exhaust valve across from each other like the old Hemi, but the combustion chamber is not a true hemi since it has a squish/quench area (a hemi has zero squish/quench).
A true hemi looks like half of a sphere...thus hemispherical combustion chamber. While this allows for much bigger valves for a given bore size (with the advantage of more flow of course), from a thermodynamic standpoint, they are the most inefficient ohv design. They have the highest combustion chamber surface area to bore ratio meaning a lot of heat is transfered to the cylinder head jacket water. The piston has to have a crown/pop-up to get compression which again gives more surface area to transfer heat versus a flat top piston. And since heat is horsepower, the more heat rejected to the coolant means less to drive the wheels affecting economy, emissions, and power. That's why Chrysler had to add a squish/quench area to the new hemi...to get the fuel economy numbers up and the emissions numbers down.
The pentroof design is widely recognized as the best. It has the lowest combustion chamber surface area to bore ratio, the highest valve "window" area (since it has 4 valves), lightest valvetrain mass, central spark plug location allowing the least amount of ignition advance (causes less "negative" work as the piston continues to TDC) etc, etc
Sorry this got long, hope it helps.
