ALDL Def file for Tunerpro?
Dominic,
To the scan tool, they may be the same...ie, same parameters output in the same sequence. In the calibration, however, they are likely different, because the RAM addresses which store the data are usually different in each calibration. But that is irrelevant to the scan tool, it just takes 0x?? byte and converts it to a defined engineering unit (like Coolant Temp).
Dominic,
lots to do
