Good & Bad
Good & Bad
Just had to tell someone about my experence . Took my 90Z out for the longest ride since Ive owned it. 3 yrs. now.drove 200 mi. 1 way also the fastest Ive. driven it .From the begining of the entrance ramp to the highway I noticed very light traffic and no one to merge into while getting on SOOOO I put the pedal down hard and went through the gears like a mad man I concentrated on the road and when I looked down I was doing 137 mph. and just as I let off the gas I heard a loud Woosh of air . my glass top popped loose on the back side I
imediatly looked behind me to see who would get it
Well the front bolts were good and tight and it heald good.
Anyways aftre tightening it in place it came loose again Has anyone else had this problem Ive. never looked at another Z is their suposed to be bolts on the back side also.? z vette murfreesboro ten.
soo
soo
There are four bolts that hold it in. Two by the windshield header that are vertical and two into the halo bar that are horizontal. Glad it didn't pop off the car!
are you talking about the horizontal bolts in the back. i could see the ones in the front comming loose but the back ones. gosh alost sounds like the female part is either stripped or missing alltogether . just some thoughts . glad it didnt come all the way off
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Did the Plexiglas come lose from the frame or was the top lose from the halo?
thanks for this quick reoly
What happened was the 2 **** like pieces on the back side popped out Iam so glad I asked about this.I bought the car this way no bolts on the back Their will be now THANK YOU THANK YOU THANK YOU I hope I can help someone with a problem sometime....... Z VETTE
St. Jude Donor '16
Nice at least you got off lucky...Just put in the new Torx bolts and your good to go..
Yeah, there are protrusions that help the top line up. But they won't hold it in securely. Bolts go through there into the halo. Glad you discovered it without anything bad happening!
