C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Changing Fluids
Old Jan 27, 2008 | 07:01 PM
LT5corsa's Avatar
LT5corsa
1994 Admiral Blue ZZZZZR1
Northeast Events Coordinator
Default Changing Fluids
Hey guys,
I haven't changed anything other than oil/anti freeze in my Z and need to do it......
Question is what fluids do you recommend and then how much of each do I need? (Quarts)
Brake Fluid
Transmission
What else do I need?
thanks!
Old Jan 27, 2008 | 08:52 PM
bldavis11's Avatar
bldavis11
Originally Posted by LT5corsa
Hey guys,
Brake Fluid
Transmission
thanks!
I would change the differential fluid as well.
Tranny fluid is kind of up to you as there are numerous opinions. Most stick with the Castrol TWS 10W60. You'll need 3L, but will only use about 2.25L. This can be purchased from your local BMW dealer.
I used the Mobil1 gear lube with the rec'd GM anti-slip additive for the rear end.
Old Jan 27, 2008 | 10:11 PM
ZR1North's Avatar
ZR1North
Hey guys,
Brake Fluid
Transmission
thanks!
Highly recommend you take a look at the "Maintenance Tips" section in the ZR1 Registery. There is a gold mine of info on good maintenance practices. The "Tech Tips" and "Common Problems" sections are also quite valuable. Good luck, and there is a lot of excellent advice and help here if you run into questions with any of it.
To Changing Fluids
