C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
My Bonneville Project up date
Old 12-13-2018, 07:00 PM
  #581
Daves obsession
Daves obsession's Avatar
Well we finally found the rpm limit for my motor at world of speed, extended operation at 8500 rpm took out the mains resulting in the number 8 piston unfriending the rotating assembly. Things went radically bad from there, so we are rebuilding the motor from scratch it was a complete loss.
I am going to sell my earlier ported plentum and injector housing, stage 3 cams, duel 53mm throttle body matched air horn.
This package made over 580 hp at the rear in a 372 cubic inch motor, 227 mph, and would make a screamer in a 415.
Also I have a mint thermostat housing for sale.
Old 12-13-2018, 11:35 PM
  #582
Z51JEFF
Z51JEFF's Avatar
What are you asking for the thermostat housing?
Old 12-14-2018, 09:26 AM
  #583
Daves obsession
Well this thermostat housing went 229.7 mph, before I removed it so $$650
disclaimer you may not see the same results ��
Old 12-15-2018, 12:05 AM
  #584
lgaff
lgaff's Avatar
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
How much for the intake....
Old 12-15-2018, 07:14 AM
  #585
Daves obsession
I will consider all offers > $4500 as I am raising money for the rebuild. similar intakes have original costs +/- $9000. Which is pretty close to what I paid for Corey to make this one. Lots and lots of painstaking time to create this artwork, this one has gone 225 mph.
Old 12-17-2018, 09:03 PM
  #586
Daves obsession
These truly end up being a one of a kind.
Old 12-18-2018, 05:49 PM
  #587
Wide_One
Wide_One's Avatar
Got any engine forensics? ….
Old 12-19-2018, 05:47 AM
  #588
Rkreigh
Rkreigh's Avatar
beautiful work! dr phil has a 427 on the stand, but I don't think you can talk him out of it
that's what I'd build might think of ITB for your next build, we're trying to muster an effort for it.
Lotus made it work well with the old calliope intake in the rear engine race cars that turned up 8500 with flat plane crank and shorter stroke
Old 12-20-2018, 01:03 PM
  #589
Daves obsession
Rpm at 8500 was starving the mains. Going to rebuild and limit rpm to 8100.
Old 12-20-2018, 01:07 PM
  #590
Daves obsession
Rebuilding the 372 back to where we were, we just pushed it to far without creating a dry sump for oiling.
Old 12-27-2018, 07:48 PM
  #591
Rkreigh
Rkreigh's Avatar
get a 3 t accusump oil accumulator will provide a nice reserve, and you can prelube the motor before starting
if you bleed that one dry, you have too long a pull
Old 12-28-2018, 10:00 PM
  #592
Daves obsession
It’s basically 2 mins wide open throttle with little time below 7500 rpm the 4 to 5 shift is a 300 rpm drop. On the top end at the wall, it’s like the old California drag down, under full torque. I really do not need to go above 81-8200 I will be just making a small gear change to the Jericho.
Old 12-31-2018, 12:44 PM
  #593
Jagdpanzer
Jagdpanzer's Avatar
With main oil distribution channeled entirely through the crankshaft drilled passages starting at the front I’ve sometimes wondered about the effects centrifugal forces at high rpm might have on oil flow to the furthest most rod and main bearings.
Old 01-02-2019, 07:56 AM
  #594
Daves obsession
You have a good point, all the bearings were smoked, number 8 was the worst and it was that rod that failed.
Old 01-02-2019, 09:07 AM
  #595
dmaxx3500
Support Corvetteforum!
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
cool,
ive got a couple 588'' BBC engs just off the dyno,,750hp at 5400,,that would make that car scream
Old 01-02-2019, 10:00 PM
  #596
Daves obsession
Records are by displacement a C motor is from 305 to 372, this is the record I am after. A 588 would be a AA motor with a record of 268 in a naturally aspirated stock body production car. We have gone 294 mph with the twin turbo A motor vette, it’s not just about going fast if it was I would use displacement and 30 psi of boost.
My goal is to set a record with the motor that originated in the car, it’s very easy to buy Hp once you move on to after market motors.
Old 01-11-2019, 10:59 PM
  #597
Rkreigh
Rkreigh's Avatar
stick to your guns. Fastlane made some big hp with a 377 motor. Look him up Haven't heard from in a while and corey may know about the motor to replicate it
short strock stock crank turned down with lighter ti rods from pauter is what I would recommend with some nice flat top pistons and some chamber work for bigger valves and to soften them up
put a much less expensive ITB intake on her and let the mighty lion roar. I also saw some "calliope" lt5 flat plane crank motors lying around that would do well.
sheesh, I want the boat motor, who bought that one. Those headers need a pair of turbos.
Daves obsession (01-12-2019)
To My Bonneville Project up date
Old 03-15-2019, 07:52 PM
  #598
95ZR1
95ZR1's Avatar
"UPDATE: State of Utah Approves $5 Million to Restore Bonneville Salt Flats
Our voices were heard! Thanks to enthusiast and industry outreach in recent weeks,
Utah state lawmakers have appropriated $5 million towards a program to restore
the Bonneville Salt Flats. SEMA applauds the Utah legislature for authorizing
these monies to fund the creation of a 10-year program to dramatically increase
the amount of salt pumped onto Bonneville. The program is now contingent
upon securing federal funds."
Rut Roh
Daves obsession (03-28-2019)
Old 03-19-2019, 06:24 AM
  #599
Rkreigh
Rkreigh's Avatar
Rut Roh
I'm posting up some pics that would be good pieces for your next rebuild
3.875 SB billet crank
Pauter ti rods
I'd be curious if we could scrounge a smaller bearing big end rod and then just use an offset ground stock crank (less bearing, lighter rod)
maybe good old sb chevy rods with a 1.88 bearing shell TI would be pretty light The comp motors in drag racing would wind up really tight with these litte fellows in the bottom end and I think it would work out nicely for a reduced bob weight and cheaper rotating assembly for the next build
diamond or JE or forged piston of choice with uber compression and the mls hg
better chains. save the intake that thing is a honey!!
or run those ITBs (really like to do this similar to C5 R intake setup!!)
8100 sounds like a good idea, with the lighter rotating assembly and the little rods, it might do better
save a buck or two as well scrounge!!!
Daves obsession (04-02-2019)
Old 04-17-2019, 07:35 PM
  #600
wdo-mkr
wdo-mkr's Avatar
Thanks for the SGC Stage 3 cams Dave. They should be here from Corey tomorrow.
Quick Reply: My Bonneville Project up date
