C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
shift lockout
Old Jan 19, 2009 | 10:58 PM
LT1 70's Avatar
LT1 70
Default shift lockout
Found where my shift lockout was disconnected by the previous owner at the mid point along the side of the transmission. Reconnected. All connections including both ends are very clean and making good contact. Still does not work. What am I missing ? Is there a fuse ? Is there a computer disconnect ? 20,000 mile clean original car. Need fixed for NCRS PV Judging.
Old Jan 20, 2009 | 12:08 AM
glass slipper's Avatar
glass slipper
What year is your ZR-1? Are you talking about the connector going to the 1-4 skip-shift solenoid? There is no "electrical" shift lockout for reverse so I assume you're talking about the 1-4 skip-shift. The '90-'93 ZF has a ring on the shifter you lift to to enable you to go to reverse and the '94-'95 has a "crash through" design where you have to push harder against a spring to shift to reverse.
Old Jan 20, 2009 | 10:20 PM
LT1 70's Avatar
LT1 70
It's the 1-4 shift lockout that does not work. It was disconnected at a junction about half way back on the same side of the transmission as the solenoid. I have it plugged back in, but still won't work. Oh, it's a '91.
Old Jan 20, 2009 | 10:39 PM
TommyL's Avatar
TommyL
Could be the previous owner installed a prom...most if not all aftermarket proms disable that feature.
To shift lockout
