radio-antenna-ignition relationship?
During this time while my Z is intermittently running rough I turned on the radio last time I moved it...and nothing happened. No antenna, and no radio power. I haven't checked the fuses yet because the car is sitting under 3 covers and it's a royal pain to take them all off and put them back. Is there some relationship between the radio/antenna and the ignition system that could be causing my rough idle and lack of power?
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
The only common link between the radio and the ignition system that I can think of is the wire that carries the tachometer signal. You know the stock radio has that automatic volume adjust feature? I'm almost positive that that system operates using an input that carries the rpm signal to the radio head unit. The only other way I can see that system operating is if it gets the VSS signal, but I still think it's the tach signal that is it's information source.
Okay, that said, if that wire had a chaff somewhere and could short against metal, I would think that it would sort out the ignition system during the contact with metal.....but that's a really long leap of faith. Something I find almost impossible to believe.
I would rather look else where for the source of the rough running motor. JMHO. Maybe the coils or the O2 sensors or something along the lines of fuel delivery. Does it seem to be a lean or a rich condition while it's running rough?
Tom
Tom
Tom
Tom
