90 zri what is the oil capacity
PHILLY JOE
I bought one with 18k on it but it has no owners manual. Question what is the oil cange capacity type and grade of oil recommended. And number for oil filter. Thanks joe
Last edited by PHILLY JOE; 06-08-2010 at 12:14 AM. Reason: HAVE MY ANSWER. THAKS TO YOU ALL. PHILLY
9 quarts plus or minus, but let it drain overnight. I use Mobil One synthetic 10w-30 and a Bosch 3401 I believe.
90 ZR1 Oil Capacity
Also check out http://pnwzr1.net & http://pnwzr1.com & http://zr1netregistry.com/ for more information & Pics.
Welcome to the brotherhood & join the ZR1 Registry.
Tomcat 74
91 ZR1 #906
Project 98
Without Filter Change - 7.6 quarts
With Filter Change - 8.6 quarts
With Oil Cooler Drain and New Filter 10.6 quarts
Complete System Drain (after engine rebuild) 11.6 quarts
I'm sure this will change if you have any after market oil cooler.
Haibeck suggest - Amsoil
High ZDDP content is not "needed" for the LT5...there are many modern DOHC engines with the "cam and bucket" design and they have zero problems with modern SAE SM oils even at 8000+RPM. As a percentage, the amount of people using Amsoil AMO here is small. Run what you want but please don't contribute to the "ZDDP" hysteria.
